SolaraGuy.com • View topic - Check Engine
Check Engine
Check Engine
Postby mattyboy243311 » Thu Feb 19, 2009 6:37 pm
I recently got my intake installed and I am getting the check engine light. I am located in the Chicago area and was wondering if anyone has any input on this. The mechanic installed it for me cause I don't have a garage and it's too cold outside. I went back he hooked it up to the computer and he told me that the sensor isn't used to the airflow on the intake and it is giving a different fuel mixture. It came up as P0171 and P0174 which means either too lean or too much. I think I might have to have it hooked it up to a computer and reconfigure everything in order to make it work properly. They told me that they don't specialize in that and I would have to look elsewhere. I would really appreciate you guys helping me out cause I don't want anything to happen to my engine and car overall. Does anyone know where I can go to get this fixed or what I can do? Any help would be greatly appreciated.
mattyboy243311
Postby Midias » Thu Feb 19, 2009 7:24 pm
Make sure the vacuum hoses are hooked up and the maf sensor is correctly bolted down. Also pull you neg battery cable for about 20 minutes then reinstall and drive for a bit to reset the computer.
Finally what brand intake. Those cheap ebay intakes are the wrong pipe diameter and can cause the MAF to do all sorts of weird things. Also they are missing a port for one of the vacuum lines.
Postby mattyboy243311 » Thu Feb 19, 2009 7:37 pm
it is a weapon r intake and what do you mean by port for the vacuum lines my mechanic blocked off one of the vacuum lines as he said it was unnecessary, maybe he just f'd it up it sucks cause I do not know much about cars
mattyboy243311
Postby mattyboy243311 » Thu Feb 19, 2009 8:35 pm
mattyboy243311
Postby Ilovemylara » Thu Feb 19, 2009 9:49 pm
he blocked off one of the lines?!?! Was it a line coming into the intake, or a nipple on the weapon-r intake itself?
Postby mattyboy243311 » Fri Feb 20, 2009 7:24 am
it was the other big line on the right he said i did not need it because the my engine drew air from on side or some crap im havin my buddy look at it today
mattyboy243311
Postby Midias » Fri Feb 20, 2009 7:33 am
mattyboy243311 wrote:??
Relax there sparky no need to bump after just an hour some of us oold folks have to work early in the morning and go to bed early.
Did the intake come with instructions? If so that is where I would start by making sure that the install looks like the instructions. Second what engine do you have that might help the rest of us help you. Even if you have already stated engine trans and intake model in another thread it is always a good idea to include all the info in a new thread if you need mechanical advice.
Postby Midias » Fri Feb 20, 2009 7:36 am
Postby Down2TheC » Fri Feb 20, 2009 12:44 pm
The bigger hose should be used still. Only a few smaller vacuum lines are no longer needed. Check the install tutorials and pictures for hte Injen and the CP-e intakes. The setup should be the same with all hoses.
Down2TheC
Postby Midias » Fri Feb 20, 2009 12:48 pm
here are injens directions should be the same.
http://www.injen.com/galleries/products ... ctions.pdf
Postby mattyboy243311 » Fri Feb 20, 2009 3:59 pm
my buddy told me that sometimes the maf sensor just needs to get get used to the flow and the filter oils need to be eliminated before the sensor goes off! Any Help I don't want to ruin my engine if I am getting lean fuel might go back to stock if all else fails!
Thanks
mattyboy243311
Postby Midias » Fri Feb 20, 2009 4:16 pm
mattyboy243311 wrote:my buddy told me that sometimes the maf sensor just needs to get get used to the flow and the filter oils need to be eliminated before the sensor goes off! Any Help I don't want to ruin my engine if I am getting lean fuel might go back to stock if all else fails!
Thanks
Might be a crazy question but did you check all the things posted?
Postby mattyboy243311 » Fri Feb 20, 2009 11:10 pm
my intake does not have the two nipples on the side for the 4mm lines I am sure I got the right intake for my model but it doesn't have it? Is there a way of going around this or what?
Thanks
mattyboy243311
Postby mattyboy243311 » Fri Feb 20, 2009 11:18 pm
it says to use Plastic "T" fitting and reconnect the 3x 4mm lines all together but then where do i run the third line too do you get where i am coming from it doesn't make sense to me since there is no way to hook them up to the in take no connectors do i just hook them up together and and let them run through eachother blocked off or what
thanks
mattyboy243311
Postby mattyboy243311 » Fri Feb 20, 2009 11:23 pm
i think i might have to fit the two 4mm lines with the other bigger hose that is supposed to be blocked off as it says in the ingen since it has the two little nipples and the weapon r doesn't?
mattyboy243311
Users browsing this forum: Majestic-12 [Bot] and 19 guests
