SolaraGuy.com • View topic - Can i add ESP?
Can i add ESP?
Can i add ESP?
Postby harp00n » Fri Feb 27, 2009 1:14 pm
I have '04 Toyota Solara SE. It doesn't have traction control. Is it possible to add it to my car (button in the car, the main block, maybe wiring)?
harp00n
Postby Black Bob » Sat Feb 28, 2009 1:57 pm
No, no, nooooo, that technology is not anyway near an "add-on". Traction control involves your brakes, your speedometer, wheel-spin sensors, three PhD's in physics, etc. etc. etc. It involves waaaaaay more than a module, a button, some wiring and a switch.
Check the link---> http://www.securitydriver.com/aic/stori ... e-111.html
Black Bob
Postby TLMNICK » Sat Feb 28, 2009 2:42 pm
I dont doubt that it can be done....but it would be EXTREMELY expensive, and will be LOTS of work. Ultimatly not worth it.
TLMNICK
Postby [SMAN] » Sat Feb 28, 2009 6:11 pm
actualy, the more i had read of the factory service manual and studied the wiring diagrams, i believe it might actualy be able to added in. It just interlinks between existing system allready, there is no aditional physical connections that aren't allready preasent in the car. However what i couldn't find out is if the factory ECY needs to be reflashed to support the VSC computer or not.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby harp00n » Wed Mar 04, 2009 2:53 pm
[SMAN] wrote:actualy, the more i had read of the factory service manual and studied the wiring diagrams, i believe it might actualy be able to added in. It just interlinks between existing system allready, there is no aditional physical connections that aren't allready preasent in the car. However what i couldn't find out is if the factory ECY needs to be reflashed to support the VSC computer or not.
thank you for your information! the question is how much will it cost :)
harp00n
Postby [SMAN] » Thu Mar 05, 2009 8:07 am
Dunno, you'd probably only be able to get it for a reasonable price from a junkyard. Spend some time with the service manuals and wiring diagrams and trace all the wires out, then compare against your own car to see if these wires exist allready.
2004 Solara V6 SE
1996 Camry I4
[SMAN]
