SolaraGuy.com • View topic - Can i put 20x8.5 offset 30 ?
Postby tolik1980 » Wed Mar 18, 2009 9:17 am
I wanna put 20x8.5 rims with +30 offset , will it fit ? if so what tires i should use to avoid rubbing ? Car is trd lowered.
tolik1980
Postby Biggi_e » Wed Mar 18, 2009 9:52 am
i think you will rub
Postby rewmomi » Wed Mar 18, 2009 1:38 pm
hell yah ur gonna rub lol roll them
rewmomi
Postby PXLpainter » Wed Mar 18, 2009 6:57 pm
Roll or trim and you might wanna consider a camber kit for the rears.
Postby tolik1980 » Sat Mar 28, 2009 1:19 pm
what about 30 offset?
tolik1980
Postby ThatVietGuy » Sat Mar 28, 2009 2:16 pm
You'll still rub.
ThatVietGuy
Postby tolik1980 » Sat Mar 28, 2009 2:49 pm
so there is no way i can use these rims ?
tolik1980
Postby Aotoyota » Sat Mar 28, 2009 3:09 pm
+35 rubs a lot, i had to chop the fender. and it still rubs a bit on
bumps
Aotoyota
Postby tolik1980 » Sun Mar 29, 2009 12:48 am
2 aotoyota
what rims you pushing ? i mean size 20x??
tolik1980
Postby SdeA » Sun Mar 29, 2009 12:50 am
tolik1980 wrote:2 aotoyota
I think he have 19x8.5 +35 off set
SdeA
Postby Aotoyota » Sun Mar 29, 2009 12:51 am
19x8.5 axis pentas with +35 offset.. on yokohama s-drives.. 235/35R19
ive already cut the entire fender out and there are still some rough spots during the bumps.
you can try but heed our warnings!
http://www.axiswheels.com/wheels.php?id=penta
Aotoyota
Postby tolik1980 » Sun Mar 29, 2009 7:58 am
what if put 20x8.5 +35 offset and 225/35 tires ?
tolik1980
Postby Aotoyota » Sun Mar 29, 2009 8:55 pm
difficult to say if a 225 will rub or not. the offset is too aggressive to begin with.
it seems like you are trying to reason that the wheels will fit?
maybe -1 degree of camber may help with too. anyone?
Aotoyota
Postby PXLpainter » Tue Mar 31, 2009 12:07 am
Paint the rims black and don't mount tires - you might not rub then.
Postby tolik1980 » Tue Mar 31, 2009 10:25 am
tolik1980
