SolaraGuy.com • View topic - air Intake
air Intake
air Intake
Postby BesI » Thu Apr 09, 2009 3:16 pm
I was wondering when you guys change the stock air intake to injen or k&n did you guys get the check engine light to come up? I cleaned the air filter couple days ago and got the check engine on but i think it must it been not closed all way. The thing that i wont to know is that when i put air intake on it do i get the check engine light on or not before i buy the intake.
BesI
Postby Ilovemylara » Thu Apr 09, 2009 3:27 pm
Dont you have the k&n drop in filter? IF thats what you mean then no, you shouldnt be geting a CEL... Check to see if the cover is seated all around.
Postby yaddadaimsayin » Thu Apr 09, 2009 3:35 pm
They say that if you did it right, you shouldn't be getting a CEL. But i've heard of quite a few cases where the CEL comes on after installing an intake because of the MAF change.
get a cp-e and you'll be good :D
Postby BesI » Thu Apr 09, 2009 3:40 pm
yaddadaimsayin wrote:They say that if you did it right, you shouldn't be getting a CEL. But i've heard of quite a few cases where the CEL comes on after installing an intake because of the MAF change.
Yeah this is what i want to make sure before i do it.
I don't like to have the light on for nothing.
BesI
Postby Biggi_e » Thu Apr 09, 2009 3:51 pm
so what do you have? a drop in k&n filter or a injen short ram intake?
Postby BesI » Thu Apr 09, 2009 3:56 pm
its just drop in k&n. thinking to get the injen cp short ram.
BesI
Postby Ilovemylara » Thu Apr 09, 2009 5:05 pm
Save your money and get a tunable CP-e.. The injen is just a noise maker.
Postby D-money » Thu Apr 09, 2009 6:58 pm
Ilovemylara wrote:Save your money and get a tunable CP-e.. The injen is just a noise maker.
unless you do the custom cai extention then you feel it
D-money
Postby GzNutz » Fri Apr 10, 2009 5:26 am
Did you try disconnecting the battery for about 15 mins then reconnecting?
Postby BesI » Fri Apr 10, 2009 6:25 pm
no i did not disconnect the battery but i got that fixed thanks guys for the tips .. i just had to take it out and put it back on ..
BesI
