SolaraGuy.com • View topic - TRD RSB Bushing Noise
Postby kin0kin » Fri Apr 24, 2009 6:36 am
Hey folks. I've been using the TRD RSB for some time now and it has been making a lot of clunking noise. The bushing itself is worn and when I brought it to the mech, he says the bushing is very hard/stiff, and it is so hard that it stripped off some of the paint on the bushing. I asked him to lube it, which then solved the noise problem for 2 weeks and it's back again. I'm in Canada and weather is cold + dry most of the time. When I installed the RSB, I used Castrol Syntec grease (couldn't find mobil 1), it was good throughout summer, fall, but once winter hits....clunk clunk clunk....anybody having the same issue or if there's anything particular that I can do to soften the rubber, or any particular grease that will keep the bushing going for a longer time.
kin0kin
Re: TRD RSB Bushing Noise
Postby Dawgz » Fri Apr 24, 2009 10:43 am
kin0kin wrote:Hey folks. I've been using the TRD RSB for some time now and it has been making a lot of clunking noise. The bushing itself is worn and when I brought it to the mech, he says the bushing is very hard/stiff, and it is so hard that it stripped off some of the paint on the bushing. I asked him to lube it, which then solved the noise problem for 2 weeks and it's back again. I'm in Canada and weather is cold + dry most of the time. When I installed the RSB, I used Castrol Syntec grease (couldn't find mobil 1), it was good throughout summer, fall, but once winter hits....clunk clunk clunk....anybody having the same issue or if there's anything particular that I can do to soften the rubber, or any particular grease that will keep the bushing going for a longer time.
What ASG14 did for me was to wrap the bushing's outer area with teflon as well as the bar where the bushing meets with teflon. I think 2-3 wraps should do it.
Postby D-money » Fri Apr 24, 2009 10:57 am
i found this sight maybe it will help someone http://www.energysuspension.com/pages/swaybbct.html i think the trd rsb is 22mm but im not sure someone correct me if i am wrong http://www.amazon.com/Energy-Suspension ... B000CN7BTS
D-money
Postby GzNutz » Fri Apr 24, 2009 12:25 pm
^x2 Putting teflon tape between both the bar and the bushing as well as the bushing and the bracket definately works. The tape is key.
Postby kin0kin » Fri Apr 24, 2009 12:31 pm
I have to confess that I did not do a search before asking the question :p I did a search after that and called my mechanic to try out the teflon tape fix. Going to get it fixed, again, this coming Monday. Is 2-3 layers realy enough? I was gonna do 6 layers or so as per the original post (from another thread). :D
I don't know about the other folks but my 2004 solara was making a lot of noises here and there and I stripped the whole interior off and almost rebuilt the whole car. I'm still having a few noise issues that I'm trying to solve. I noticed that if I keep my roof opened, driving at 70km or so would cause the interior door to rattle like ****.
kin0kin
Postby swindler » Fri Apr 24, 2009 4:18 pm
I've had the same problem, and am currently using teflon tape and Mobil 1 synthetic grease, but I still have to re-apply every now and then.
But I've read really good stuff about this Dupont grease, and it's really easy to apply. I thought I might try it next time.
http://www.amazon.com/dp/B000GKTZIW
Has anyone here tried it?
2006 SLE V6 Convertible
swindler
Postby kin0kin » Fri Apr 24, 2009 6:08 pm
I've seen it. I personally sprayed jig-a-loo (invisible teflon lube) and greased the crap out of the bushing with castrol syntec when I first installed it. I'm definitely gonna see if the teflon tape fixes this problem.
kin0kin
Postby swindler » Fri Apr 24, 2009 6:42 pm
You might want to make sure that the bushings haven't worn on the inside and become out-of-round. That might cause it to rub regardless of the grease/tape.
I've also noticed that the bushings run real close to the elbow of the RSB - too close. I've always wondered if that causes excessive rubbing if the RSB happens to lean to one side during a turn. But I doubt that's the problem.
swindler
Postby Sparky5e » Sat Apr 25, 2009 2:50 pm
07 SLE Convertable
Blue Streak Metallic
Sparky5e
Postby LEE337 » Sat Apr 25, 2009 11:42 pm
Two words: Teflon Paste. 8)
Postby dvdchris45 » Sun Apr 26, 2009 2:10 am
What about finding some TEFLON bushings that are the same size as the TRD bushings? That'll eliminate the need for grease, teflon paste, etc... altogether!
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
