SolaraGuy.com • View topic - Finally slamming(okay just lowering) the car. some questions
Postby BadAngel » Mon Apr 27, 2009 6:35 am
Okay so I'm finally going to lower my car after new rims and an annoying gap but i have a couple questions and concerns first.
-First I have 18x8 Tork Imagine rims at (either 20 or 40 mm offset i have to check and make sure but i believe its 40) am i going to run into rubbing problems, and if so how would i remedy this?
-Second, I have a 2004 v6 SLE and i really want to tighten up the suspension to make the car handle better at the same time... should i get stiffer shocks with my new springs to achieve this effect or what? any suggestions would be great.
-Third, I'm planning on just getting the TRD lowering springs. Is there a better option than this? I found them here:
http://www.trdsparks.com/displayparts.p ... rts_id=231
I think this is a good price... what do you guys think?
Any suggestions/experiences/input would be very greatly appreciated guys and thanks for taking the time to read!
-Rob
BadAngel
Postby [SMAN] » Mon Apr 27, 2009 8:10 am
for prices on TRD parts, talk to reggie. He can usualy hook you up with a better part. If your getting the TRD springs, you should get stiffer struts, however that might be a challenge as it seems the only confirmed stiffer struts are the SE Sport ones. I've only seen aftermarket ones for the regular setting found on the SE and most SLE editions. A TRD Rear Sway Bar will also stiffen things up aswell. But talk to reggie and see what he can do for a price. Ohh, and TRD springs won't "slam" the car, to do that, you'll need atleast coilovers or airbags or something like that.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby BadAngel » Mon Apr 27, 2009 8:26 am
okay so i exadurated a bit lol... shoulda just said lowered hahahha
BadAngel
Postby Dawgz » Mon Apr 27, 2009 8:40 am
Its gonna look pretty dope!
I bet ur gonna miss that 4x4 look...:-P
Postby BadAngel » Mon Apr 27, 2009 8:42 am
Dawgz wrote:Its gonna look pretty dope!
lol... jerk
BadAngel
Postby kingkakyle » Mon Apr 27, 2009 12:57 pm
no rubbing
i have 18X8 with 40 offset if i remember correctly and i dont rub
Postby BadAngel » Mon Apr 27, 2009 2:56 pm
cool... not even when you have the car loaded up with people or go over a nice dip?
BadAngel
Postby kingkakyle » Mon Apr 27, 2009 3:39 pm
only time i had to make peolpe get out was on a really sharp driveway....
i was rubbing and scrapping and got stuck lol
but on big bumps/dips i go slowly and dont have any problems rubbing
Postby BadAngel » Mon Apr 27, 2009 3:59 pm
cool thanks.... im trying to figure out the offset but i keep coming up with diff numbers.... according to the site they come in 20mm and 40mm and according to my measurements its 38... so im gonna go with what the site says... 40mm
BadAngel
Postby Maniax » Mon Apr 27, 2009 4:26 pm
How much did u get those rims for?lol.Theyre very clean.
Maniax
Postby GzNutz » Mon Apr 27, 2009 4:34 pm
If you are going to get stiffer shocks, then why not go with the tein coilover set up?
Also- what size tires do you have?
I changed from 45's to 50's for a smoother ride and instantly got rubbing in the rears. A few mallet hits later and no rubbing at all.
Postby Aotoyota » Mon Apr 27, 2009 4:59 pm
kyb shocks are avail for the gen 2 . I have them paired with the trd springs.
or go tein. i went trd because i didnt want to be that low.. just lowered.
:lol:
Aotoyota
Postby BadAngel » Mon Apr 27, 2009 8:07 pm
Im not about to drop 1300 on coilovers >.<
Maniax wrote:How much did u get those rims for?lol.Theyre very clean.
uhh i got them off of Craigs list... payed 500 for all four rims and three good tires... on wheelsnext that setup is over 1100 new
GzNutz wrote:If you are going to get stiffer shocks, then why not go with the tein coilover set up?
uhh they r Nexen n3000's 245/40ZR18 tires... i don't really care about ride smooth-ness that much honestly I'm used to corvettes and the porsche which are stiff as crap i don't mind all that much...
BadAngel
Postby GzNutz » Tue Apr 28, 2009 4:36 am
That was a great pick up for that price.
Postby BadAngel » Wed Apr 29, 2009 12:42 pm
any other suggestions guys?
-Rob
BadAngel
