SolaraGuy.com • View topic - For thoes of you with KYB GR2 Struts i have a few questions
Postby BadAngel » Fri May 01, 2009 2:07 pm
Allright, so since i JUST realized that lowering on the SLE struts is a horrible idea, I decided to get some KYB GR2's to go along with my TRD lowering springs. Now i have a couple of more questions for those of you who have done the same thing.
1) As asked before with 18x8 rims that have a 40 mm offset, no rubbing correct?
2) How much better is the performance over the stock SLE setup?
3) Did you install them yourself and how hard would you say it is. (did you need an alignment after as well?)
4) Did the camber of your wheels stay straight? i have been told that i should look into a camber adjustment kit if i change out the struts... i don't think this is an issue but what do you guys think?
BadAngel
Postby ThatVietGuy » Fri May 01, 2009 2:24 pm
For number 4, you ABSOLUTELY need to go get an alignment done after lowering. I didn't after I lowered my car and the insides of my tires were instantly eaten away.
ThatVietGuy
Postby LostSoul » Fri May 01, 2009 5:46 pm
i have 18/8 w/35 offset no rubbing issues
pretty stiffer youll feel the diff
i didnt but it took my mechanic about 2 1/2 hrs. i had already taken off the rear seats and side panels so he had enough room to work around alignment 4 sure
they stayed the same no need
also "aotoyota" can tell a bit more
LostSoul
Postby Aotoyota » Fri May 01, 2009 8:28 pm
My Turn~.
That should be fine, im running 19x8.5 with a +35 offset and rubbed a whole lot to where I cut the fender out.. How lostsoul isnt rubbing makes me scratch my head?
I have an se sport and it got much smoother after I was lowered on stock wheels, it felt more stable in ever aspect but without sacrificing ride quality ( according to gf too)
buddy and I did it, and alignment is a must! it as bad bad, I did it after two weeks to let it all settle,
install looked easy, since my buddy did most of it and was about 3-4hrs? biggest pain was removing the back seat and everything else. on a diff note, I changed to kyb strut mounts also, since I had new shocks and springs, might as well change the mount too. cant tell you if it made a diff, but the new one seemed more sturdy?
it took the guys at toyota 3 hrs but they got it to practically straight.
shouldnt require a camber kit since they are factory trd springs, and are made within the cars suspension geometry.
and for the record, I believe we are the only two who have this suspension? i was the first and Lostsoul was the second? Why everyone buys the SE sport shocks still confuses me? since the oem shock says
KYB on it also... and they are about twice as much?
Aotoyota
Postby BadAngel » Fri May 01, 2009 8:44 pm
SO what am i going to have to remove to take the back ones out?
BadAngel
Postby Aotoyota » Fri May 01, 2009 9:13 pm
all of the back...
unscrew seatbelts
remove the interior panels
c pillar,
seats ( back and bottom?)
pretty much everything...
Aotoyota
Postby BadAngel » Sat May 02, 2009 6:06 am
Everything in the back of the car huh?
My main concern with this is the rubbing... cuz i wont be able to tell until AFTER i get it all togeather and crap... so like yeah if it rubs its like wow okay 800 bux and now my wheels rub LOL
BadAngel
Postby Aotoyota » Sat May 02, 2009 9:45 am
seems to me a +40ffset should be ok to run without rubbing?
and if it does, an airsaw + grinder fixes just about everything!
can someone chime in on the TRD wheel offset? arent they 40ish or something?
Aotoyota
Postby kingkakyle » Sat May 02, 2009 12:46 pm
trd rims are 40
