SolaraGuy.com • View topic - upgraded alternator
upgraded alternator
upgraded alternator
Postby Aotoyota » Fri May 08, 2009 8:51 pm
Has anyone found or bought an upgraded high output alternator for the 2AZ motor???
if so, how much juice? where and cost??
Aotoyota
Postby Solara08861 » Sat May 09, 2009 12:07 pm
I have a 220 ampIraggi Alternators
range was around $500.
Iraggi Alternators
121 Highland St, La Vergne, TN 37086-2940
(615) 287-7991
Solara08861
Postby Aotoyota » Sun May 10, 2009 3:42 pm
great thanks! any ideas on what the oem puts out? I read 80Amps somewhere?
Aotoyota
Postby panic » Sun May 10, 2009 4:11 pm
There's probably some higher rated alt from a Tundra etc. that would have a winch that can be adapted.
panic
Postby kingkakyle » Sun May 10, 2009 5:55 pm
the previous gen highlander should have one that fits
at least ive read that somewhere on the boards
Postby gnegroni » Sun May 10, 2009 6:27 pm
Search the topic and you shall find my little grasshoppa
gnegroni
Postby Aotoyota » Sun May 10, 2009 6:34 pm
Ive searched and the highlander alt is for the v6 motor, I have the 2az four banger...
sooooo as far as I know, there is nothing else other than a
custom ordered one that will be a direct bolt on??
Aotoyota
Postby kingkakyle » Sun May 10, 2009 6:59 pm
the highlander came in a 2az form as well
i would think they would have a higher powered one compared to our solara ones also?
just in case u didn't check ;)
Postby Solara08861 » Sun May 10, 2009 8:30 pm
Iraggi has different amp alts for the 2az. It depends how much you willing to spend
Solara08861
Postby Aotoyota » Mon May 11, 2009 3:19 am
kingkakyle wrote:the highlander came in a 2az form as well
I thought our gen 2 solaras were underpowered! to think that Toyota
threw the motor into a highlander too? geez.
thanks for the info everyone. Ill look into in highlander but I believe I will
go with the Iraggi alt instead.
Aotoyota
Re: upgraded alternator
Postby alky181 » Sat Jul 30, 2011 10:13 pm
I know that using a Capacitor, like a 1mf. It does take some strain off the alternator. The capacitor is like a battery itself. It stores then releases energy. Just don't get shocked. It hurts
alky181
