SolaraGuy.com • View topic - 2az-fe motor gurus
2az-fe motor gurus
2az-fe motor gurus
Postby Aotoyota » Mon Jun 15, 2009 5:41 pm
are all 2az-fe motors the same? in particular the alternator?
I found that the highlander with the 2az-fe motor has a 130amp alternator
but will it bolt onto the solara 2az motor? It seems to make sense but does anyone have any info on it?
cheers
Aotoyota
Re: 2az-fe motor gurus
Postby Kfra315 » Fri Sep 10, 2010 2:54 pm
I really need an answer to this question ASAP. I know the V6 2MZ alternator bolts right on but I can not seem to find an answer specifically for the 2AZ V4. I've googled and searched the forum for 24 hours.
Kfra315
Postby Aotoyota » Fri Sep 10, 2010 5:49 pm
nope alternator isnt the same, the voltage regulator on the alt is diff, both in
size and configuration
I also found out that the alternator is specially wound isnt too fun to
work on, this info was from ohio alt.
i thought someone here got one made 200amps?\
Aotoyota
Postby Kfra315 » Sat Sep 11, 2010 9:13 am
Thanks man.
My alternator is pretty much done so I was need this answer pretty quickly.
What kind of alt did you end up putting in your solara?
Kfra315
Postby Aotoyota » Sat Sep 11, 2010 11:06 am
havent ordered one yet, alt seems to be working still.
but i think i might just keep with the stock alt
Aotoyota
