SolaraGuy.com • View topic - instructions for removing stock radio to install aux input
Postby prometheus » Tue Jul 14, 2009 6:08 pm
i bought this aux input on ebay
http://www.peripheralelectronics.com?ProductId=95
seems pretty easy to install i just need instructions on how to get behind the radio (so basically removing and reinstalling radio after i have attached it ).
cant find any on the search.
thanks
2005 black Gen 2 Solara.
K&N hp air filter. peripheral Aux Input
...yah thats it for now.
prometheus
Postby drewcrane » Tue Jul 14, 2009 6:22 pm
i too would like to know some info on radio/stereo removal
"its a vanishing point thing you wont understand"
drewcrane
Location: 13.7 sec.s @bandimere ,5800 ft above sea level
Postby Ilovemylara » Tue Jul 14, 2009 6:30 pm
edit
Postby Taido » Tue Jul 14, 2009 6:32 pm
A taped screwdriver and 10mm socket wrench or something similiar is all you'll need.
First pry off the emergency light button from the top part. Not just the cap, the actual button. That hole will help you to pull the A/C vent piece out. But don't just yank with all you've got. When you've got it loose just set it up top out of the way so you can unscrew the two bolts you see.
Then pull the e-brake, twist off the shift knob, and open the middle arm rest. Pull up on the center piece with the cup holders and set it off to the side. Now pull out the little compartment below the A/C controls to expose two more bolts. There's three there but ignore the far left one. Now you can pull out the headunit.
Taido
Audiophiliac
Audiophiliac
Postby prometheus » Tue Jul 14, 2009 7:14 pm
is there a trick to taking off the air vents above the radio, i took everything else off, and was able to access the bottom bolts, just cant seem to get the vent off to access the bolts on top, any help
prometheus
Postby Taido » Tue Jul 14, 2009 7:29 pm
Just pull. There's just some plug like things holding it in.
Taido
Audiophiliac
Audiophiliac
Postby Ilovemylara » Tue Jul 14, 2009 7:37 pm
Ahh. sorry I didnt notive you were gen 2. :-?
Postby kingkakyle » Tue Jul 14, 2009 8:22 pm
if its just an aux for the stock radio
u might not have to remove the radio at all to install
just remove the trim below and reach under and behind haha
Postby prometheus » Tue Jul 14, 2009 9:17 pm
WOO HOO SUCCESS!!!! after 2 hours of playin around with it trial and error the triumph is mine!!!
First i would like to thank GOD for giving me this oppurtunity to work on my car.
second, MAJOR thanks to TAIDO for his very wise wisdom. with out you i would have never even started this giant project.
third to ILOVEMYLARA for trying to assist.
and to all who supported me through the process.
thank you and God Bless us all :drinking:
prometheus
Postby Ilovemylara » Tue Jul 14, 2009 9:26 pm
prometheus wrote:WOO HOO SUCCESS!!!! after 2 hours of playin around with it trial and error the triumph is mine!!!
You sound as if you just found a 100 dollar bill laying on the ground lol
Postby NightRider » Wed Jul 15, 2009 11:42 am
kingkakyle wrote:if its just an aux for the stock radio
For future reference for other readers, this is all you have to do***
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby yaddadaimsayin » Wed Jul 15, 2009 12:06 pm
hahahah! shoutout to my homies!
Postby BesI » Wed Jul 15, 2009 12:31 pm
soo you did installed .. what button to you press to switch over the ipod or whatever you have connected too .. i have been looking for Aux for my ipod but i don't wanna pay over 100 box for something like that ...
BesI
Postby prometheus » Wed Jul 15, 2009 1:13 pm
once you select the disc button you just press it again and you should hear the ipod playing.. the volume needs to be turned up a little bit more than normal to hear,
i bought mine off ebay for 59.99 free ship
prometheus
Postby BesI » Wed Jul 15, 2009 2:26 pm
prometheus wrote:once you select the disc button you just press it again and you should hear the ipod playing.. the volume needs to be turned up a little bit more than normal to hear,
Did you get something like this ?? Also after you connect it with the radio you don't have control over the ipod right ? so can't you have the volume set up high ?? Also the music comes out clear ?
http://cgi.ebay.com/ebaymotors/2003-200 ... otohosting
BesI
