SolaraGuy.com • View topic - camber kit
camber kit
camber kit
Postby Aotoyota » Thu Jul 16, 2009 7:43 pm
anyone have a camber kit on their car?
if so what brand and where did you get it?
ive got about -1.5 degrees of camber on the front
and they advised that I get a kit if possible?
help?
Aotoyota
Postby BadAngel » Thu Jul 16, 2009 8:28 pm
uh oh... i just ordered my KYB GR-2's and the trd springs r sittin here lol am i gonna have neg camber too?
BadAngel
Postby Aotoyota » Thu Jul 16, 2009 8:51 pm
I took my car to get aligned at toyota, and they were within toyota specs
actually the maximum negative camber allowed for the car
service guy suggested I look for a camber kit just to save some of the tires.
Aotoyota
Postby NightRider » Fri Jul 17, 2009 9:18 am
Hey bro here's what I found. Im sure there is more out there but just thought i'd help. :sweet:
http://www.andysautosport.com/toyota/20 ... ts/eibach/
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby [SMAN] » Fri Jul 17, 2009 10:38 am
The front camber is adjustable through bolts. If you look in the factory service manual in the front strut section, you'll see that it shows how they can put different sized bolts in to adjust the camber. As for the rears, i think those in the link above should work.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby Aotoyota » Sat Jul 18, 2009 1:15 am
thanks for the replies~
I called Eibach and they dont have any official camber kits for the car. BUT I suspect that the gen1.5 solara camber kit is the same.
Eibach did refer me to spcperformance.com and they offer a camber kit for the 92-2009 solaras. Guy over the phone said its the same part for both of them ..
and should anyone want to get them the cheapest place was to order from
http://www.autoexp.com/ about $30/set
both front and rear will have +/- 1.75
Im still debating on getting them since Im at odds with do I really need them? These are the TRD springs on the car which should be within factory
specs and adjustments? maybe it expect too much!?
Aotoyota
Re: camber kit
Postby LostSoul » Sat Jul 03, 2010 3:51 pm
old thread from the dead lol!!!
but i jus got an alignment and they suggested front right and right rear camber kit i was getting f.r.-1.8 and r.r.-2.5 so wit the camber kit i got f.r.-0.5 and r.r.-1.1
was that way off? im lowered on trd's
jus thought id share
LostSoul
Re: camber kit
Postby Aotoyota » Sun Jul 04, 2010 9:17 am
thanks surge!
funny thing is that by adding the camber kit the rubbing
in the back is gone now!
Aotoyota
Re: camber kit
Postby Keyboard Ninja » Sat Mar 12, 2011 1:32 pm
Old thread I know, but did the camber kit fix the problem?
My 2004 Solara has camber wear on all 4 tires. I run the stock 17inch tires at the stock height. Anyone?
Keyboard Ninja
Re: camber kit
Postby GzNutz » Sat Mar 12, 2011 3:59 pm
Keyboard Ninja wrote:Old thread I know, but did the camber kit fix the problem?
Have you gotten an alignment done recently? Since you're not lowered you shouldn't need the camber kit.
Re: camber kit
Postby Keyboard Ninja » Sat Mar 12, 2011 6:11 pm
I have Firestone's lifetime alignment and get it checked every oil change. I'll post the specs when the misses comes home, but they claim everything is within spec. They said the same thing the last time my tires wore down to the thread as well.
Keyboard Ninja
