SolaraGuy.com • View topic - slotted / drilled rotors are they noisy?
Postby LostSoul » Wed Sep 09, 2009 4:25 pm
got them installed about two weeks ago and i keep hearing a grinding noise from the rear rotors i asked the mechanic who installed them and he said it was the pads have to get used to the new rotors and have to wear down but its annoying anyone have this problem??
also it was a straight swap he didnt re-adjust the brakes or anything he said it wasnt requiered so was he suppose too??
thanks
LostSoul
Postby BadAngel » Wed Sep 09, 2009 5:10 pm
I did it myself a month ago. No weird noises, no adjustments necessary basically just plug and play. I dunno what to tell you about weird noises, I know i didn't experience anything like that.
BadAngel
Postby bbq bob » Wed Sep 09, 2009 5:18 pm
i don't know about a grinding noise , but a whiring kind of noise is common with drilled rotors when applying the brakes. :drinking:
bbq bob
Postby LEE337 » Wed Sep 09, 2009 5:25 pm
What kinda pads are you useing???
Postby LostSoul » Wed Sep 09, 2009 5:27 pm
oem's
LostSoul
Postby LEE337 » Wed Sep 09, 2009 5:36 pm
^uhmmm...I dont think the OEMs are such a good idea with drilled/slotted.
Did you get the ebay rotors or some Supra TT ones???
Im about to do the TRD4life BBK w/Supra TT drilled/slotted rotors.
So I went with EBC Redstuff brake pads. 8)
Postby LostSoul » Wed Sep 09, 2009 5:37 pm
i went with r1concepts rotors
LostSoul
Postby [SMAN] » Wed Sep 09, 2009 6:57 pm
I did an R1 setup, but i got their generic ceramic pads that they offered. There shouldn't be a grinding noise with them when you don't apply the brakes (there shouldn't be any noise as there should not be any contact). Of course when you first put on new pads and rotors, you need to bed them (10 - 15 high speed stops from like 70mph down to 20 all in a row) to get them to fit. Slotted/vented are going to make a little noise when you apply the brakes but i barely even notice it and that's only with the windows down. OEM brakes i believe are semi metalic, so they will make a bit more noise than ceramics, but still you shouldn't hear anything when your not using them.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby JamesT » Wed Sep 09, 2009 7:06 pm
If they are making noise when you aren't braking. Check the rubber boots on the caliper pins. If the pins are stuck, than the brakes might be dragging.
How many miles are on the pads?
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby NightRider » Fri Sep 11, 2009 10:49 am
Do what James states and please clarify if this noise is coming from rolling or braking.
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby mazen222 » Fri Sep 11, 2009 3:19 pm
no noise here... i have the r1concept slotted and drilled with ceramic pads... no noise
1999, 5 Speed V6
mazen222
Postby Toy1mzfe » Fri Sep 11, 2009 3:43 pm
bbq bob wrote:i don't know about a grinding noise , but a whiring kind of noise is common with drilled rotors when applying the brakes. :drinking:
I get whiring noises with my dimpled and slotted rotors.
Postby PXLpainter » Mon Sep 14, 2009 7:35 pm
R1 Concepts drilled/slotted rotors are noisy compared to OEM - even ore so with the high-performance pads than with OEM pads (and they create a LOT more dust too!) - but worth the gripping/stopping power they give! :up:
Postby BadAngel » Mon Sep 14, 2009 10:29 pm
PXLpainter wrote:R1 Concepts drilled/slotted rotors are noisy compared to OEM - even ore so with the high-performance pads than with OEM pads (and they create a LOT more dust too!) - but worth the gripping/stopping power they give! :up:
Really? I haven't noticed that much of a sound increase... Then again maybe you heard it more because of the drop top?
BadAngel
Postby mik3y » Wed Sep 16, 2009 6:19 am
that's just air running thru the drilled holes... perfectly normal
mik3y
