SolaraGuy.com • View topic - HID's in stock foglights.
Postby philosophicaljt » Sat Nov 28, 2009 1:35 pm
These are my stock Solara foglights with 3000K hid's in them. They don't have a good cutoff line, but I honestly don't see any glare I consider unreasonable. To be honest, they look like they have less glare (which I'm sure isn't the case...)
Inside the shop I work at. Middle of the day, with lots of surrounding light...
I have OEM Xenon headlights with oem bulbs for low beam, HIR bulbs for high beam, and need foglights for driving in the winter and foul weather.
It's my old 55w Apexcone ballast with some 3000K 35w bulbs (over-powered obviously). They are brighter than my oem 35w low beams, lol.
I'll get some night pics tonight.
2004 Solara SLE V6
Search
philosophicaljt
Postby Ruski » Sat Nov 28, 2009 2:39 pm
very nice i wanted to put hids in my fogs where did you mount the blasts ?
Postby mazen222 » Sat Nov 28, 2009 5:00 pm
thats what i have in my fogs too. 3000k 35w. make a huge difference in visibility.
i mounted the driver side ballast next to the horn which is just behind the fog light... and the passanger side i dont even remember
1999, 5 Speed V6
mazen222
Postby Ruski » Sat Nov 28, 2009 5:06 pm
You own a Gen1 the Gen 2s have more room to mount
Postby philosophicaljt » Mon Nov 30, 2009 5:55 am
Here are some night shots. I was going to retrofit my old headlights projectors into my fogs, but couldn't find a good way to do it.
OEM Xenon headlights:
And foglights up start-up:
2004 Solara SLE V6
Search
philosophicaljt
Postby kpxboi0619 » Mon Nov 30, 2009 9:12 pm
maybe you should lower the angle for the fogs...that's what I did
kpxboi0619
Postby rohand » Wed Dec 16, 2009 9:21 pm
I have the same set up, and in less than 2 months, they blew my fuses. I replaced them yesterday, but when I turned on my fogs today, my fuses blew again, within a few minutes. I put in new ballasts yesterday after replacing my fuses, thinking that may the root of the problem. Apparently, I was mistaken
rohand
