SolaraGuy.com • View topic - DISGUSTED!!!- JUST INSTALLED TIRE/RIM COMBO AND THEY RUB!!!'
Postby Joe Cat » Sun Nov 29, 2009 11:14 am
I have mmr hr3 18's 42 off set
I also have a lexus ls430 which is the same bolt pattern so i tried a tire that would work for both cars- Not into that rubber band look-
225-55-18 and the rears rub the lower shock tower any suggestions!!!
I have a 25 mm spacer and then it rubs the outer fender, then i had a 10mm spacer
now it doesnt rub the fender but the lower shock tower -
Question if i lower the air pressure in the tire---aahhh what a stuopid question just typing it sounds stupid-----NOw What??
new Tires I guess!
Joe Cat
Postby unbalancedwood » Sun Nov 29, 2009 11:23 am
15 or 20mm spacer?
When you put the 25mm on and it rubs the fender, if you took it back 5mm would it help?
unbalancedwood
Postby Joe Cat » Sun Nov 29, 2009 11:26 am
How could i - Its a solid withe the studs and all-
The 10mm I had was a cheap spacer - I would hate to go more without having more stud to grab on to -- What do you think-
I mean i could order another spacer 5mm and give a shot, But do you think that would be enough Grab on the lugs>????
Joe
Joe Cat
Postby PXLpainter » Sun Nov 29, 2009 11:43 am
I had 225/40/18s and they didn't rub on a -30 offset (G35) rim. I hate the rubber band look as well, but you might need new tires. Check out the Sticky thread on wheel/tire calculators and see what should fit before spending more time in frustration (and $$).
Cheers - Jeff
Postby ---CAMRAZY--- » Sun Nov 29, 2009 11:45 am
That's a huge sidewall...
Postby PXLpainter » Sun Nov 29, 2009 11:46 am
---CAMRAZY--- wrote:That's a huge sidewall...
LOL! Look whose sayin' - the guy who gets that tool dip and just paints it on rims! :lol:
Postby JamesT » Sun Nov 29, 2009 1:00 pm
I agree - for an 18 inch wheel, that ends up being much bigger than the stock wheel diameter.
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby yaddadaimsayin » Sun Nov 29, 2009 5:57 pm
whats a rubber band look?
Postby Aotoyota » Sun Nov 29, 2009 6:17 pm
Whats a Lexus IS 430?
Aotoyota
Postby ThatVietGuy » Sun Nov 29, 2009 6:25 pm
yaddadaimsayin wrote:whats a rubber band look?
When the tire's like a 15 series (i.e. almost no sidewall to speak of, think of cars with dubs)
Aotoyota wrote:Whats a Lexus IS 430?
He wrote a lowercase L, not an uppercase I ;)
ThatVietGuy
Postby Joe Cat » Sun Nov 29, 2009 7:41 pm
HAVE A QUESTION:
Since the top of the tire touches the bottom of the shock tower- Would it be okay if it just clears it???
I assume it rides up and down with the wheel- As I would like to go with a
215 - 55 - 18
What do you all think?
Joe
Joe Cat
Postby Toy1mzfe » Sun Nov 29, 2009 7:51 pm
Naw man.. 55 on a 18 is way too much.
Rock a 225/40 or 45/18
That shoudl be fine.
Postby Joe Cat » Sun Nov 29, 2009 8:01 pm
that too low profile- that less than stock- I am looking for that juicy ride not the low profile look.
Do you think it will work and what about clearing the bottom of the shock??
Joe
Joe Cat
Postby Toy1mzfe » Sun Nov 29, 2009 8:12 pm
Then go with 17's
Our wheel well only have a certain amount of space. Unless you roll your fenders u gonna rub.
use this. miata.net/garage/tirecalc.html
Postby kingkakyle » Sun Nov 29, 2009 8:25 pm
well since u wont use the tire calculator
our stock size is 215/55/17
215/55/18 would make the tire 3.7% larger overall
while a 225/45/18 would make is 1.3% smaller
you are supposed to get closest to stock diameter as possible
and trust me if you get good enough quality tires you wont notice a more uncomfortable ride
for me i think my 225/45/18 ride much smoother and comfortably than the stock 17s
i think technically 235/45/18 is the closest u can get, but u will most likely get rubbing because of its width
