SolaraGuy.com • View topic - equalizer
equalizer
equalizer
Postby khim » Sat Feb 13, 2010 3:10 pm
I have an 04 solara sle with a sound system that has an eq.
My deck is the jbl stock with navigation. My system has a couple of amps and some subs in the trunk and the only way to turn up and down the volume is with the eq.
My question is: is there an eq that I can buy that will hook up with the stock radio so that the volume can be controlled from the steering wheel and the actual stereo deck itself?
khim
Postby Taido » Sat Feb 13, 2010 6:09 pm
I know you can wire up and mount a separate knob for both amps. But I'm pretty sure doing it through the head unit won't work.
Taido
Audiophiliac
Audiophiliac
