SolaraGuy.com • View topic - another rim question
Postby kpxboi0619 » Wed Feb 17, 2010 1:35 pm
I know I read the wheel/tire thread but just wanted to double check
would this fit? my lara is not lowered.
18x8.5 Sportmaxx Gunmetal with Machine finished lip. +35 or +38 offset
tires: 245/45/18 Yokohama Advan S4 All around.
my last deal with the guy selling the TSW didn't go through so
I'm taking this one this weekend.
oh and I need to get the lug nuts and I was looking at it online
# Available in:
# 12mm X 1.50RH (For most Acura, Honda, Toyota, Mazda, Mitsubishi, Daihatsu)
# 12mm X 1.25RH (For most Nissan, Subaru, Suzuki)
so I need to get the 12mm x1.50RH right?
kpxboi0619
Postby kingkakyle » Wed Feb 17, 2010 5:25 pm
i think those tires are gonna be too wide....
best size would be 225/45/18 for closest to stock size
or even 235/45/18 if you want a little more sidewall
Postby indiglosolara » Wed Feb 17, 2010 6:00 pm
12mm*1.50 is the right size...
I think you should run 235/40 rather then 245/45.. that tire size is way too big...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby .onetohate » Wed Feb 17, 2010 6:40 pm
tires won't fit, but either offsets will..
for new tires, go 225/45-18 if yr not planning to lower
and if you are, go 225/40-18.
.onetohate
Postby kpxboi0619 » Wed Feb 17, 2010 6:48 pm
I thought it would fit because I read this thread that said
235/45R18 = 668.7mm = .06% difference (not common high performance tire size) (watch clearance)
245/40R18 = 653.2mm = 2.3% difference (watch clearance)
245/45R18 = 677.7mm = 1.4% difference (watch clearance)
since it's not lowered I thought it would fit...?
kpxboi0619
Postby Aotoyota » Wed Feb 17, 2010 7:10 pm
im on a 19x8.5 with 235/35R19 +35 yoko s-drives.
I had to cut the fender since I have it dropped on trd springs.
a 245 will certainly give you lots of rub. but if you're not lowered
may not have that problem?
Aotoyota
