SolaraGuy.com • View topic - DIY K&N Apollo
DIY K&N Apollo
DIY K&N Apollo
Postby ADAMnQuickSOLARA » Fri Feb 19, 2010 2:57 pm
UPDATE: I dont recommend this K&N Apollo because the corrugated tubing kills air flow...live and learn....my new mandrel bent aluminum CAI performs MUCH better.
You can see it here:
http://gen2performance.blogspot.com/
RC-5052AB / RC-5052AS
Additional accessories include a range of stepped adaptors: 70mm – 70mm (part 85-6002), 70mm - 60mm (part 85-6003), and 70mm - 80mm (part 85-6001). A saddle bracket kit (part 85-6004) for easy mounting to your vehicle is also available.
The Apollo is ideal for normally aspired engines up to 250BHP and turbo engines up to 350BHP. It allows for updating your intake system while retaining a closed environment.
While waiting for the K&N to show up I wanted to make the first half of the CAI....here's the Short Ram intake, great sound...LOUD!:
Cold Air Intake: Design #1. I have another idea in mind to eliminate the 90 degree piping bend and I think that may help performance. The CAI sounds great, not as loud as the Short Ram, performance seems equivalent but I will test each to confirm. I will reset the computer and then time each intake on the same stretch of road from 40 to 80 mph.... once the weather clears. I've found that to be a pretty accurate measure since traction is not an issue.
PICS:
Piping with Mass Airflow Sensor Adapter, breather hose adapter and 2 vacuum line adapters:
A few pics of the K&N Apollo "closed" Cold Air Intake System (universal):
Cold air piping side (inlet):
Throttle Body Side (outlet):
Yes, it is serviceable, can be cleaned, re-oiled, re-used like any K&N Filter.
Finished Product (sorry so dark):
Pics of how it's routed into the front bumper to pick up cold air:
Thoughts? Opinions?
Last edited by ADAMnQuickSOLARA on Mon Apr 12, 2010 12:26 pm, edited 10 times in total.
ADAMnQuickSOLARA
Postby GzNutz » Sat Feb 20, 2010 6:40 am
How do you plan on tuning?
Postby NightRider » Sat Feb 20, 2010 10:39 am
Good luck with the outcome keep us posted!
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby ADAMnQuickSOLARA » Sat Feb 20, 2010 1:27 pm
GzNutz wrote:How do you plan on tuning?
we'll see how it works out w/o tuning first...
havent researched tuning yet...maybe an apexi afc neo...what, if anything, have people here used?
i've mapped out the plumbing and i'm going to come off the throttle body into the 3" dia. maf adapter pipe (about 6" long), then into a 3" dia short ram pipe (about 10" long)....and then into the K&N apollo (filter end)...the goal is to have the expandable tubing of the apollo start towards the front of the engine bay, away from the heat and then route into the front bumper where it will pick up the cold air....i had the whole intake assembly out already and it looks pretty straight forward....fabricating brackets is going to be the only tough part i think....
07' red 'vert SLE
Eibach / KYB / 20 x8.5" +35 / 245/35-20 / CAI
http://www.cardomain.com/ride/3827989/1
ADAMnQuickSOLARA
Postby ADAMnQuickSOLARA » Wed Feb 24, 2010 10:07 pm
bump...updated orig. post with pics/details...
07' red 'vert SLE
ADAMnQuickSOLARA
Postby ToyoSolV6 » Wed Feb 24, 2010 10:28 pm
looks good man, its different than anyone else's
props!
Postby kpxboi0619 » Thu Feb 25, 2010 1:22 pm
Great to be Unique
kpxboi0619
Postby x99suplarax » Thu Feb 25, 2010 2:11 pm
i was gonna do something similar with the cpe but the tube isnt connected to the filter.. pretty much other end near the filter has a mesh.. and other end by the bumper with a fan..
x99suplarax
Postby NightRider » Thu Feb 25, 2010 3:28 pm
It looks coo but I don't like that you can see the opening of the tube and it's all out in the open.
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby Midias » Thu Feb 25, 2010 3:54 pm
Put something over the end even some screen door just to keep rocks out.
Postby DriDed » Thu Feb 25, 2010 4:16 pm
Can you do a driving video of the car?
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Postby kingkakyle » Thu Feb 25, 2010 11:32 pm
NightRider wrote:It looks coo but I don't like that you can see the opening of the tube and it's all out in the open.
could just add a grille down there
like mikeT or billets
which reminds me i need to repaint mine.....
Postby ADAMnQuickSOLARA » Fri Feb 26, 2010 6:40 am
there's no chance of inhaling anything...not only would the closed K&N filter stop it but the picture is deceiving...the tube is actually facing the psgr side of the car, its not facing forward...and its behind the bumper, not in the opening...no way to pick up rocks or rain...you dont even have to make it come around the radiator support if you dont want to...you can have it end in the inner fender or even behind the fog light if you're worried about it...
yea i plan on making a video of the SRI and CAI once it stops snowing (sunday) and the roads are clear...
07' red 'vert SLE
ADAMnQuickSOLARA
Postby ADAMnQuickSOLARA » Fri Feb 26, 2010 6:59 am
Once you have the stock intake out, the installation time is about 5 mins for the SRI, and 10 minutes for the CAI and requires only a 10mm wrech and flat head screwdriver.
To switch between SRI and CAI takes about 1 minute.
Last edited by ADAMnQuickSOLARA on Wed Mar 31, 2010 10:49 am, edited 1 time in total.
07' red 'vert SLE
ADAMnQuickSOLARA
Postby Maniax » Mon Mar 15, 2010 12:17 pm
I would be interested but i have a 4cyl.
Maniax
