SolaraGuy.com • View topic - fog light stop working
Postby 5speed » Sun Mar 21, 2010 6:44 pm
hey guys i need some help.
my fog lights on my 2004 solara has stoped working. i replaced the two fuse that controls them with new ones,and they still dont work.
i then tested them with a test light and to my suprise there was no current flowing through them. is there anything else that i can do.
plz help cause i have a set of hids that i wpold love to hook up....
thankz
5speed
Postby 99BlackSandv6 » Sun Mar 21, 2010 8:36 pm
You need new bulbs. If power gets to them, but not through them, they're burned out.
fog loght not working
Postby 5speed » Mon Mar 22, 2010 12:17 pm
the bad news is that i just replaced the whole fog light ficture and bulbs ..
so i know that the blub is good.
the thing is i also replaced the fuse (located under the hood)with new ones so i know thoses are also good . but when i place a test light onto the new fuse it had no power to it, i then took out the fuse and placed the test light into the main port where the i took the fuse out from,and thats when i noticed its was not the fuse that was bad.its because there is no power flowing to the fuse box for the 2 fuse need to power on the fog light. so what i was hoping o find out is there another fuse box somewhere else in the car or is there a fog llight relay.i dont know what to do. fustration is kicking in.
brand new hid kit and i cant use it....
thanks for all your help and advice.......
5speed
Postby TheBossMan » Mon Mar 22, 2010 1:08 pm
i know there is a fuse box in the pull out box thing to the bottom left of the steering wheel. you just pull that thing out and there are a bunch of fuses
Edit- i dont know if you have one of those things in your gen 2 but check the manual thats how i replaced my fuses.
2002 i4 solara :agrue:
TheBossMan
Postby 1gSE » Mon Mar 22, 2010 2:54 pm
basically you're gonna have to go chasing wires and find the last source of power
Solara-M62 @ 5.5psi
1gSE
Postby GzNutz » Mon Mar 22, 2010 3:10 pm
Is it possible the harnesses weren't plugged back in?
Postby 5speed » Mon Mar 22, 2010 4:07 pm
Hey guyz thanks for all the help...
i finally got it working..it was the fuse that was located under ther steering wheel.. DO U KNOW HOW MANY TIMES I LOOKED UNDER THERE AND I NEVER SEEN THAT BOX...it was covered from paint dust i just got the car out from the bodyshop.
it was raining and i got wet but it was worth it,cause now i can hook up my HIDS...... fuq yea
5speed
