SolaraGuy.com • View topic - Velcro?
Velcro?
Velcro?
Postby tSse06 » Fri Mar 26, 2010 11:37 am
I'm probably soon to buy some HIDs from DDM tuning, and it doesn't come with any attachment brackets, etc. If any of you guys have these, what did you use to attach them?
I was thinking of using velcro or should i just attach them with zip ties?
tSse06
Postby 99BlackSandv6 » Fri Mar 26, 2010 12:28 pm
Velcro tends to be a little heat sensitive. I'd go with something a little more permanent.
Postby kingkakyle » Fri Mar 26, 2010 6:46 pm
there are some bolts you can attach to
also i used high heat?/3M tape
but yea.....there should be some bolts you can use in the engine bay area
Postby BadAngel » Mon Mar 29, 2010 1:29 pm
3M double stick tape
BadAngel
Postby SoSleek » Thu Apr 01, 2010 1:28 pm
The tape that should be used is called 3M VHB. (stands for Very Strong Bond, lol) it is the strongest bonding mounting tape there is :)
SoSleek
Postby SoSleek » Thu Apr 01, 2010 1:30 pm
I know I mentioned this in the response to your PM, but the kit comes with mounting tape. If you do not feel comfortable using the tape provided, invest in some 3M VHB tape.
SoSleek
