SolaraGuy.com • View topic - Replacement Wheels
Replacement Wheels
Replacement Wheels
Postby JustBrian » Thu Apr 08, 2010 7:21 pm
Hi everyone I just joined the group a few minutes ago because I have a question for which I have not yet found the answer in over a month of searching the net.
I now own a 2007 Solara Sport. It is my second Solara. I had a 1999 for a few years.
It is some sort of pale blue - don't remember the color name - and so far I have installed a gold kit for a bit of accent and next the wheels will be replaced when the tires need to go. I have seen some brass and gold wheels the correct size which would compliment the color of the top but I can not determine what the impact of new wheels will be on the tire pressure monitoring sensors.
The dealer tells me the wheel must be drilled to the correct angle or I will have to replace the sensors. Being the cheap SOB that I am I would prefer not to spend the extra >$400 for new sensors if I can find wheels ready to take the stock sensors. Anyone know anything about this issue? What wheel spec is the driver?
JustBrian
Postby ThatVietGuy » Thu Apr 08, 2010 7:46 pm
The Solaras don't use a sensor: it measures the difference between how much each wheel spins to determine if one is low on air.
ThatVietGuy
Postby kingkakyle » Thu Apr 08, 2010 8:00 pm
ThatVietGuy wrote:The Solaras don't use a sensor: it measures the difference between how much each wheel spins to determine if one is low on air.
actually he has a gen 2.5 so i think he does have sensors
Postby JustBrian » Thu Apr 08, 2010 8:09 pm
What about this information? http://www.toyotatpms.com/
There is a sensor of some sort connected to the valve.
JustBrian
Postby ThatVietGuy » Thu Apr 08, 2010 8:39 pm
I stand corrected; forgot all about the gen 2.5 :drinking:
ThatVietGuy
Postby GzNutz » Fri Apr 09, 2010 4:43 am
I assume you mean dealership when refering to 'dealer'.
Where do you plan on getting your rims from? I sugguest you check with them to see if they'd swap them for you since you're already going to be spending some decent cash there. Also, the dealer is going to try to get more money out of you, so call around to wheel shops to see if the rims have to be drilled as they would have a better idea.
