SolaraGuy.com • View topic - camber kit?
camber kit?
camber kit?
Postby Aotoyota » Sun Apr 25, 2010 10:35 am
has anyone put an aftermarket camber kit on their car?
i have trd springs and kyb gr-2 shocks and it cant be aligned to zero.
Aotoyota
Postby GzNutz » Sun Apr 25, 2010 11:16 am
I believe Jeff (PXL) had installed one.
Postby GzNutz » Sun Apr 25, 2010 11:22 am
Postby Aotoyota » Mon Apr 26, 2010 11:39 pm
thx...gonna put the order in tomorrow
Aotoyota
Postby BadAngel » Fri Apr 30, 2010 9:25 am
I have the same setup, and i have no camber issues o.O
BadAngel
Postby stringbean » Fri Apr 30, 2010 12:29 pm
i was browsing this because of camber but now i have a question about the kyb gr-2 im planning on buying some for my other car, none yota, but wondering how they are? are they stiffer? lower? or just a oem replacement? thanks sorry for being off topic
stringbean
Postby bbq bob » Fri Apr 30, 2010 2:56 pm
I have camber kits front and back . I did not do it for the tires . It helps while cornering . 1 1/2 Deg. front and 1.0 Deg. for the rear . It will wear your tires funny .
bbq bob
Postby Aotoyota » Fri Apr 30, 2010 5:26 pm
[quote="BadAngel"]I have the same setup, and i have no camber issues o.O[/quote
really? I think there is a difference and I bought new
kyb strut mounts all around too. Are you at 0 or close to it?
And stringbean the whole setup is a bit more firm but not horrible personally I'd like a stiffer ride like tokico blues or something like that
Aotoyota
Postby BadAngel » Mon May 03, 2010 12:21 am
I didn't get the mounts... and i don't believe i'm at zero but if I remember correctly I'm pretty darn close... close enough for it to not make tire wear issues.
I also got the alignment at the stealership... so you know if I needed it they would have been bugging me to install it so they could screw me on labor.
BadAngel
Postby Aotoyota » Mon May 03, 2010 7:38 pm
BadAngel, what size wheels are you running? and does offset affect the camber? I took it to the dealership too and my buddy/service writer suggested I get a camber kit
either way i ordered a set of the Eibachs F/R
here are the part numbers if anyone wants to mess with camber?
Eibach 5.81290K Fronts
Eibach 5.81270k Rears
found them for$26 each set on Amazon.
Aotoyota
Postby BadAngel » Thu May 06, 2010 1:06 pm
I have 18 inch rims and Im not sure if offset affects camber... i would imagine that if u have camber issues and you screw with the offset it could make the tires wear worse because they are sticking out further or less, I know my offset isn't right because i have rubbing issues with too much weight in the car...gotta roll the fenders...
BadAngel
Postby turboman412 » Thu May 06, 2010 3:14 pm
nothing about the wheel's will affect camber.
turboman412
