SolaraGuy.com • View topic - HID fogs
HID fogs
HID fogs
Postby tSse06 » Mon Jul 12, 2010 9:31 pm
I've recently installed an HID kit for my solara (low beam) only. Looks great but doesn't really go great with the OEM fog lights, i've been thinking of buying another HID kit for the fogs but I don't know what temp goes great with my current kit.
Current Temp:
55w 6000K low beam
What temp should be the fogs?
MARK
2006 Toyota SE V4
8K lows, 6k fogs, 6k license plate lights
tSse06
Re: HID fogs
Postby NightRider » Wed Jul 14, 2010 9:50 am
Go with the yellow fog setup. It will look cleaner!
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Re: HID fogs
Postby SoSleek » Wed Jul 14, 2010 10:17 am
They should be 35w 5000k to match your headlights. Since 55w shouldn't be used with fog housings (excess heat) you should drop to 35w. Since 55w (higher wattage) wash out some color compared to 35w you will need to lower your Kelvin (K) by one color temperature.
SoSleek
Re: HID fogs
Postby yaddadaimsayin » Wed Jul 14, 2010 10:51 am
NightRider wrote:Go with the yellow fog setup. It will look cleaner!
I agree. 6k on top, 3k on bottom.
Re: HID fogs
Postby NightRider » Wed Jul 14, 2010 3:10 pm
Thats what I have 6k on top and 3k on bottom :)
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Re: HID fogs
Postby GzNutz » Wed Jul 14, 2010 4:56 pm
SoSleek wrote:They should be 35w 5000k to match your headlights. Since 55w shouldn't be used with fog housings (excess heat) you should drop to 35w. Since 55w (higher wattage) wash out some color compared to 35w you will need to lower your Kelvin (K) by one color temperature.
^x2
Stay away from 55w kits for the fogs. I tried it, and only blew fuses. The stock wiring can't handle the draw.
3k ftw!
Re: HID fogs
Postby kingkakyle » Thu Mar 17, 2011 7:34 pm
where did u guys mount the fogs exactly
i already have headlight ones and cant find a good place to mount the fogs =T
Re: HID fogs
Postby GzNutz » Thu Mar 17, 2011 7:41 pm
I had the bumper pulled off the front and screwed the ballast brackets on to the outer sides of the frame.
Re: HID fogs
Postby kingkakyle » Thu Mar 17, 2011 7:51 pm
GzNutz wrote:I had the bumper pulled off the front and screwed the ballast brackets on to the outer sides of the frame.
=T i wanted to avoid removing the bumper lol
Re: HID fogs
Postby Solarasian » Fri Mar 18, 2011 1:25 am
thank goodness i read this. i was gunna put my lowbeam hids into the fog and getting bi xenons for the headlights
Auto SLE V6
6000k VVME Bi-Xenon
GReddy SP2 catback
injen SRI is2030p
Kaminari Lip Kit(stand by)
Tokico hp Struts
Tein S Tech
Solarasian
Re: HID fogs
Postby kingkakyle » Fri Mar 18, 2011 2:07 am
Solarasian wrote:thank goodness i read this. i was gunna put my lowbeam hids into the fog and getting bi xenons for the headlights
it wouldn't have fit anyways lol
different bulbs type no?
Re: HID fogs
Postby Solarasian » Fri Mar 18, 2011 2:24 am
cant i buy diff bulbs?
Auto SLE V6
6000k VVME Bi-Xenon
GReddy SP2 catback
injen SRI is2030p
Tokico hp Struts
Tein S Tech
Solarasian
Re: HID fogs
Postby DSM_Lara » Fri Mar 18, 2011 2:29 am
It can work if you think alot harder.
DSM_Lara
Re: HID fogs
Postby Solarasian » Fri Mar 18, 2011 2:32 am
lol i think ill just get the yellow bulbs for fogs. im so jealous of ur fog lights tho
Auto SLE V6
6000k VVME Bi-Xenon
GReddy SP2 catback
injen SRI is2030p
Tokico hp Struts
Tein S Tech
Solarasian
Re: HID fogs
Postby wkbrdr91 » Thu Mar 24, 2011 5:42 pm
No need to remove the bumper. I was able to install it without pulling the bumper off. Just lift the car up a little (even driving it on a piece of wood is fine since thats sturdier) and turn the wheel all the way to the right when working on the drivers side, and left when working on passenger side. Youll still be albe to mount the ballast to the frame no problem :D
2006 Solara Sport
wkbrdr91
