SolaraGuy.com • View topic - Intake K&n or Injen
Intake K&n or Injen
Intake K&n or Injen
Postby Maniax » Thu Aug 05, 2010 9:30 am
I know i prob asked this in the past but i have been gone for a while since i have had personal matters to attend too.I was doing research on the k&n sri and the injen sri.I know the injen can be converted to a Cold air intake but i have not been able to find anything about that with the k&n.I do not know if it would be that beneficial to have a cold air since i have a L4 engine.Opinions?
Maniax
Re: Intake K&n or Injen
Postby DriDed » Fri Aug 06, 2010 1:34 pm
There are 2 Injen sri intakes for your car, #1) SP2026
, and
#2) IS2025 Image.
Short ram intakes will be safer, less chance of hydro-locking. The benefits of either of intake types over one another are minimal at best.
Tacti's old Solara has the IS2025 but he had a custom piping done to make his short ram intake into a cold air intake.
I haven't seen any Solara owners make a cai out of a K&N sri so far so I can't tell you.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Postby Maniax » Fri Aug 06, 2010 2:13 pm
Thank you.I guess the IS2025 is a little smaller and i can get the heat shield.Thank you for also answering i was not sure if anyone was going to.Yeah i did some research on Tactis car before also. Do you know if their is a sound difference between both?
Maniax
Postby DriDed » Fri Aug 06, 2010 4:56 pm
Maniax wrote:Thank you.I guess the IS2025 is a little smaller and i can get the heat shield.Thank you for also answering i was not sure if anyone was going to.Yeah i did some research on Tactis car before also. Do you know if their is a sound difference between both?
There is no sound difference between the IS2025 and SP2026.
I think the Injen SP2026P is better because it is farther away from the engine than the IS2025, less heat going on around there.
+TRD rear sway bar
DriDed
