SolaraGuy.com • View topic - Idle Problems Weapon-R Secret Weapon
Postby tevansroskos » Sat Nov 26, 2011 12:47 pm
Recently installed the weapon-r secret weapon intake onto my 06 solara se 5 speed and it works fine seemingly. Only issue im having is that lately my car idles at around 200 rpm... doesnt seem right to me. Any feedback on this? possible fail with the maf sensor or something?
tevansroskos
Re: Idle Problems Weapon-R Secret Weapon
Postby GzNutz » Sat Nov 26, 2011 7:52 pm
Have you unhooked the battery for 15mins, connected back up, then started your lara and let it idle for at least ten minutes?
Postby tevansroskos » Fri Jan 06, 2012 5:15 pm
Have done. The check engine light comes on after about 150 miles and thats where my idle problems are starting. Hooked it up to a gizmo that gave me engine issue codes and its saying i've got a vacuum issue wit cylinder 6 not getting enough air. I've checked seals, made a better seal for the MAF and adjusted position, etc. I don't want to spend money on a new MAF until i have to so if you've got any ideas that would be fantastic.
tevansroskos
Postby 1gSE » Sat Jan 07, 2012 8:32 am
cylinder 6? :think: What code is it giving you?
Solara-M62 @ 5.5psi
1gSE
Postby GzNutz » Sat Jan 07, 2012 9:40 am
Aren't you a 2az?
Postby GzNutz » Sat Jan 07, 2012 9:43 am
I would try cleaning your maf. Possibly the filter that came with the intake was over oiled is throwing your reading off.
Postby tevansroskos » Sun Jan 08, 2012 11:34 am
Well that was dumb. Cylinder 4. dont ask me why i said six... that makes no sense even to me. But i will try cleaning the maf. if no change ill get back to you. Thank you for the help.
tevansroskos
Postby tevansroskos » Sun Jan 08, 2012 3:58 pm
Cleaned the MAF. Working like a charm thank you very much for the suggestion.
tevansroskos
Postby GzNutz » Sun Jan 08, 2012 4:55 pm
Great! Glad to hear it worked out.
Postby tevansroskos » Fri Feb 10, 2012 7:57 am
Ok so Idle problem is worked out by cleaning the MAF, but im still getting P0171. I posted another post with more details on everything i've done so far.
tevansroskos
Postby wkbrdr91 » Sat Mar 10, 2012 10:41 pm
Assuming you have an oil filter, make sure to seafoam regularly. Oiled filters make a mess out of the engine internals I hear.
2006 Solara Sport
wkbrdr91
