SolaraGuy.com • View topic - Sway bar bushings
Sway bar bushings
Sway bar bushings
Postby Solara08861 » Mon Mar 19, 2012 2:57 pm
I have TRD rear sway bars and I need to replace the bushings. Is the factory and TRD sway bars same size?
Solara08861
Re: Sway bar bushings
Postby minig646 » Wed Mar 21, 2012 2:50 pm
No, the TRD sway bar is much thicker.
minig646
Postby Solara08861 » Wed Mar 21, 2012 4:02 pm
minig646 wrote:No, the TRD sway bar is much thicker.
Do you know where I can get replacement ones that can fit the TRD one?
Solara08861
Postby minig646 » Wed Mar 21, 2012 9:32 pm
You might try a google search and get lucky, but I'm pretty certain they were never sold separately from the sway bar itself. May I ask why you need to replace them? I didn't think polyurethane wore out easily.
minig646
Postby minig646 » Wed Mar 21, 2012 9:33 pm
minig646
Postby Solara08861 » Thu Mar 22, 2012 7:35 am
minig646 wrote:You might try a google search and get lucky, but I'm pretty certain they were never sold separately from the sway bar itself. May I ask why you need to replace them? I didn't think polyurethane wore out easily.
When I bought my rsb in 04 it did not come with it. My factory one was rigged to fit it and now it's worn out.
Solara08861
Postby CmeFLY » Fri Apr 20, 2012 1:03 pm
hey did u have any luck finding the bushings? my sway bar never came with is. and now its worn up and squeaks like crazy. ITS SO ANNOYING!
[2006 3.3 SLE]---[2 12' Kenwood subs]---[ECLIPSE DOUBLEDIN]---[INJEN SRI]---[TRD RSB/ FSB/ SPRINGS COMING SOON]---[15% tint front 5% tint rear]---[8000k top / 3000k bottom]
CmeFLY
Postby Projex0 » Fri Apr 20, 2012 2:10 pm
CmeFLY wrote:hey did u have any luck finding the bushings? my sway bar never came with is. and now its worn up and squeaks like crazy. ITS SO ANNOYING!
are you sure yours is worn up? the squeeking can be fixed by adding some lub, i slaped on some synthetic grease which helped.
since were on the topic of the bushings find out how thick the TRD rsb and find a round universal bushing that matches the stock shape of the original bushing
Projex0
Postby Solara08861 » Fri Apr 20, 2012 2:34 pm
Have not had any luck finding them.
Solara08861
Postby Projex0 » Sat Apr 21, 2012 12:49 am
please check how thick the TRD sway bar is, the inner hole might not be big enough
here you go
http://www.rockauto.com/catalog/moreinfo.php?pk=1147250
Projex0
Postby CmeFLY » Mon Apr 23, 2012 3:12 pm
thanks guys. ill try using some grease on it and see what happens.
CmeFLY
Postby Aotoyota » Sun May 06, 2012 10:07 pm
search...
viewtopic.php?f=2&t=42110&p=484829&hilit=rsb+bushing#p484829
i called them last year and told them i needed replacement bushings for the trd sway bar..
Aotoyota
