SolaraGuy.com • View topic - TRD Air Filter 04 Solara
Postby cydog3 » Fri Apr 30, 2004 6:20 pm
I installed a TRD air filter ,I noticed I can see a little of the filter after tightening down the bolts I've tried taken it off and putting it back on a few times and it still shows The stock one is completely covered. Can you tell me if this is how it's supposed to be or should I keep trying to get it completely enclosed?
The red area in the picture is what I am talking about
Thanks in advance
cydog3
r u sure?
Postby boaclub923 » Sat May 01, 2004 1:37 am
damn, my 1st post didn't work, i need to type everything again.. -_-;;
anwyay
i'm not sure about TRD air filter, but i do know some other similar product like K&N Filter, they have particular direction to install it...
look at the filter more carefully, it should indictates which side face up or front.
u want ur filter to be FULLY COVERED, u dont' want gap around and allow unclean air goes into ur engine... it wont' be fun~
best luck
boaclub923
Postby cydog3 » Sat May 01, 2004 6:04 am
it says front on it which I have toward the front of the car ..Well I'll take it apart again and see if it will sit better
cydog3
Postby cydog3 » Sat May 01, 2004 6:47 am
Well I can't get rid of it . I do belive it seals on the rubber of the filter so it's most likely a non issue . But I will go back to the factory one until I can figure this out .
cydog3
Postby onefiend » Sat May 01, 2004 11:06 am
cydog3 wrote:Well I can't get rid of it . I do belive it seals on the rubber of the filter so it's most likely a non issue . But I will go back to the factory one until I can figure this out .
I had the same problem with the trd replacement filter for my 01. I dont think you'll be sucking dirty air in since the gap is above the filter.
onefiend
Postby erasat » Wed May 05, 2004 12:37 pm
Don't worry, my K&N filter just does the same, only one that seems to fit perfectly is the OEM.
erasat
Postby cydog3 » Wed May 05, 2004 12:41 pm
Thanks
cydog3
