SolaraGuy.com • View topic - TRD Rear Sway Bar Now Available for the 04 Solara!
Postby cydog3 » Thu May 06, 2004 6:19 am
TRD Rear Sway Bar Now Available for the Solara!
Increase the stability of the 2004 Solara with TRD’s new rear sway bar. Constructed of mild steel, the sway bar is lightweight and features seamless tubing powder-coated in TRD red. Three adjustable positions are incorporated into the design – two street and one competition setting -- allowing for a reduction in body roll and improved vehicle stability. Factory brackets and hardware are utilized for an easy installation.
Application is detailed below.
TRD Part No.
Application/Description
00602-48800-101
2004 Solara; 2002-2004 Camry
Performance Specifications:
Change in Stiffness
1” of Travel Street (Outer Hole)
1” of Travel Street (Middle Hole)
1” of Travel Competition (Inner Hole)
TRD vs. Stock
85% Street (Outer Hole)
100% Street (Middle Hole)
116% Competition (Inner Hole)
Change in Diameter
.600” OD stock vs. .750” OD TRD
*Performance Results
*Stock
.715g 300’ Skidpad
58.35mph 600’ Slalom
*** TRD Performance Wheel/Tire Set & Springs
.817g 300’ Skidpad
65.1mph 600’ Slalom
***TRD Performance Wheel/Tire Set, Springs & Sway Bar
.834g 300’ Skidpad
67.18mph 600’ Slalom
LEGEND
*All tests done with 2004 Solara SE V6 coupe
**Stock wheels & tires are – Toyota cast aluminum, 5-spoke wheels mounted on Bridgestone Turanza P215/55/R17 tires
***TRD Performance wheels & tires are – 18” 5-spoke cast aluminum wheels mounted on Michelin Pilot Sport P225/45/18 tires
***TRD sway bar set at stiffest setting
cydog3
Postby Yanks0114 » Thu May 06, 2004 10:50 am
