SolaraGuy.com • View topic - would a p225/55/17 tire fit my gen 2 solara I4?
Postby michaels artic frost » Tue Jun 15, 2004 7:54 pm
They should fit fine. Check out this link that slingshot had posted a while back, I found it to be very helpful. It helped me determine if 245/35/20s would fit and yes it does. http://www.miata.net/garage/tirecalc.html
Thanks slingshot...
Last edited by michaels artic frost on Wed Jun 16, 2004 8:31 am, edited 2 times in total.
Updated 06/01/12: Michael T's
Postby michaels artic frost » Wed Jun 16, 2004 8:32 am
Your main concern is the overall diameter and with the size that you are getting it's not bigger than stock, so that should be okay.
Postby Mole » Wed Jun 16, 2004 10:20 am
if you get the wrong offset, then problems can occur.
im sure gen 2 folks can chime in on what is the ideal offset.
Postby michaels artic frost » Wed Jun 16, 2004 11:25 am
I got this info from http://www.bigwheels.net/package_list.jsp?req=find&startfrom=1&vehicleyear=2004&vehiclemake=Toyota&vehiclemodelOld=Solara&vehiclemodel=Solara&sized=0&finish=&brand=&sortRimsBy=size
Hope this helps.
Bolt Pattern: 5x114.3 (5x4.5); Offset: 34 to 43mm; Rims: up to 20x8.5. Tires: up to 245x690mm. OEM: 215/60-16 (215x664mm)
