SolaraGuy.com • View topic - HIFONICS ZEUS ZX4400 4-CH AMP
Postby Turbosolara » Mon Aug 23, 2004 1:36 am
brand new in box with separate bass control, $190 pick up @ riverside
trust068@hotmail.com
RMS Power Ratings
4 x 55 Watts @ 4 Ohms
4 x 110 Watts @ 2 Ohms
2 x 220 Watts @ 4 Ohms
New Hifonics Twentieth Anniversary Heat Sink Design
Illuminated Hifonics Badge
Illuminated Maxxsonics "M"
Bass Remote with Blue LED Power On & Diagnostic Indicator included
Ultra-Fi MOSFETS
Zeus EVXP (Exponential Vari-Power Supply)
SPC - Simpatico Coil Design
HSMD - Hifonics Surface Mount Design
Fully Adjustable
4 Gauge Power Connectors
Class AB Operation
Maxi-Fuse
Gold Plated Inputs and Outputs
4/2 Ohm Stable
Bass Remote Control With Diagnostic LEDs Included Zeus Series
Encased with a new generation heat sink, Zeus offers two, four, five and mono amplifier designs. Plus, each comes with a bass remote control so you can attenuate bass output. Inside, the Zeus series is a marvel of amplifier designs. Bi-polar output transistors are mounted to their own TR bracket to dissipate heat evenly and effectively. The hand wound torroids use large copper coils to provide instantaneous power to the transformer.
The epoxy coated spec 4 boards used provide reliable operation under strenuous conditions.
MOSFET OperationAll Zeus Amplifiers utilize full MOSFET operation and use the latest high votage, high speed devices. These HG (High Grade) MOSFET outputs are of the premium variety and are selected for their low ate to Drain Charge?which allows the Hifonics onboard power supply controller to essentially rev the devices to a higher clock speed, making operation more efficient.In addition, we add to additional MOSFETS for to each Zeus Model for higher output.High Grade PCBOur High Grade PCB is designed from the ground up with a superior ultra-clean layout for minimal signal to noise loss and is designed to flex with any vibration maintaining its molecular structure in extreme heat.
Beefy Power SupplyThe Zeus Series premium power transformer coil uses the latest in efficient winding techniques to ensure optimal amperage temperature. These large torroids have 20% more copper wiring and turns than our competition. In addition, its state of the art design deflects any unwanted EMF flux, ensuring that your amplifier will remain cool.
