SolaraGuy.com • View topic - testing water: complete 5SFE turbo kit
Postby Turbosolara » Wed May 18, 2005 2:07 am
1. I will NOT part out anything from this kit
2. California buyer prefered because i need to swap some parts with you.
3. Perfect fittment for 5 speed 5sfe gen 4 camry or solara, automatic, i am not sure.
I think i will sell the turbo kit at middle of July. I
will sell it for all parts + trade with factory parts
for $4000. It might sounds alot for a used kit but I
am giving you everything that is associated with turbo,
perhap the most complete force induction kit you can
find. I paid almost $8000 for all the parts and here is
the list.
lol the best part is that it already
experiemented on my car for 40000 miles and didnt
cause any problem at all. Perhape it is the most fun and reliable blower kit you can have. My car still runs like new beside few oil leak (messy installation). I believe with 3" exhaust and
lighter pulley and clutch, you should able to put down 200whp
easily.
I need factory fuel rail from you, oil pan, fuel pump
unit, valve cover and a header. mabye some more little
stuffs, or maybe not. If you have any question, please
feel free to ask.
Engine:
Custom Turbo kit from turbo-performance $3,400
Polished T3 turbo with .58 trim
Mandrel bent header
Blitz super sound blow off valve
Turbonuetics Deltagate Mark II wastegate
Spearco polished front mount intercooler
Custom Nicole plate piping and header
K&N air filter
3SGTE map sensor $50
Greddy oil catch can $90
Stainless steel oil lines, pressure pipes
Full custom 2.5” exhaust all the way $150
Magnecore 8,5mm spark wires $150
Denso Iridium IK22 $50 (less than 400 miles)
RC engineering 310cc fuel injectors $450
Greddy E-manage fuel computer + injector & ignition
harness $370
Greddy Profec E-01 boost controller/monitor display $500
Custom 4 gauge ground kit with gold plated terminal
$40
Custom Earl stainless steel radiator pipe $45
TRD oil cap $35
Thrmowrap heat shield $50
Walbro 255 lph high flow fuel pump $100
with custom pump bracket by justin aka wraith
valve cover vent modification $60
dyno tunning $600 done by Autolink, Dr. Charles
Brand new OEM oil pan $200
modified fuel rail with 3SGTE fuel pressure regulator
Apexi turbo timer with A/F ratio display $100
Greddy 60mm Electronic boost gauge $160
Greddy 60mm Electronic EGT gauge $170
Dual gauge pod $35
O2 sensor stimulator $40
brand new oil pan $150
modified valve cover $70
or you can buy the whole car for $13900 or trade me your car that has $14000 value (so i can trade it in). I am open to trade any lexus beside ES series.
Postby michaels artic frost » Wed May 18, 2005 3:56 am
Good luck with the sale. Any dyno numbers for your turbo kit?
-M 8)
Updated 06/01/12: Michael T's
Postby Turbosolara » Wed May 18, 2005 10:41 am
dynoed 185 whp and 187lb torque with
63000 miles on the motor
91 octane fuel
2.5" exhaust
stock clutch & flywheel
with Factory Catalyst Convertor ---> aka hp limiter
Postby greeensolara » Wed May 18, 2005 4:49 pm
will this work for AT????
greeensolara
Postby Turbosolara » Wed May 18, 2005 10:52 pm
I have no idea since i never check out the underhood of an automatic solara. but i think it should
