SolaraGuy.com • View topic - FS: OEM parts for Gen5 & Gen3 Camrys
Postby Luc » Tue May 24, 2005 5:17 pm
I have a few OEM parts for sale, all in USD:
Gen5 SE steering wheel with airbag & cover panels, $300
Picture 1
Picture 2
Picture 3
Gen3 Parts
12204-62010: PCV valve (1), $6 shipped
11213-62020: valve cover gasket (2), $30 shipped
04465-30080: front brake pads, $35 shipped (V6 only)
The tri-spoke is pure leather wrapped. If you own a Gen5 Camry LE or XLE, this would be a plug-n-play.
The PCV valve & valve cover gaskets will work with either 3VZ-FE or 5VZ-FE.
1998 S/C'd 1MZ-FE A/T
Luc
Postby krawzyazn » Tue May 24, 2005 6:31 pm
If that fits the solara I'll take Gen5 SE steering wheel with airbag & cover panels, $300
Postby Luc » Tue May 24, 2005 7:50 pm
The steering wheel should fit, but I'm not sure if the airbag / horn plugs will work with your Gen1.5. The only certain way is to lift your airbag module up and check the plugs. That way, you can also measure the diameter of the inner hub the steering wheel would fit through, so to be sure. You shouldn't have to disconnect any plugs. These are my suggestions, as I don't want to see our getting frustrated if the steering wheel and airbag turn out not fitting.
Luc
