SolaraGuy.com • View topic - FS: Eclipse PA5422
FS: Eclipse PA5422
FS: Eclipse PA5422
Postby Jackass-Jeff » Sat Jun 04, 2005 11:14 am
This amp powered my components... never heats up... always ice cold to the touch and looks cool
www.eclipse-web.com wrote:200W 4 Channel Max. Power Output at 2
120W 4 Channel 0.1% THD at 2 Stereo,
20–20,000Hz@13.8V (RMS Continuous Power)
85W 4 Channel 0.1% THD at 4 Stereo,
ChannelFlex Crossover High-Pass Crossover (12dB/octave, 120Hz)
Adjustable Low-Pass Crossover
(12dB/octave, 50–200Hz)
Adjustable Pre-Out High-Pass Crossover
Subsonic Filter (0–50Hz)
Free-Flow Signal Circuit
Double-Sided PCB
High-Current, High-Speed Output Devices
High-Efficiency, High-Energy MOSFET Power Supply
Audiophile Grade Component Selection
Intelligent 7-Way Discrete Protection Circuitry
Music Reproduction with Low Distortion & Ultra-Low Negative Feedback
Efficient Cooling with Low-Profile Heatsink
Multi-Mode Configuration
Stereo/Mono Switch
2 Stable Design
Retail is $399. Looking for $300.
1GR-FE ftw!
Jackass-Jeff
