SolaraGuy.com • View topic - diy disaster, so WTB: instrument cluster
Postby hanatsuki » Wed Sep 21, 2005 2:36 am
need a instrument cluster, ASAP
will be heading out to the junkyard this weekend, but if anyone knows where i can get one used and cheap please do tell. THanks
here's my story
basically tried installing the glow gauges using various tutorials from this forum and other places as well. Tried the fuse box, tried using vampire taps and connecting to the green striped wire, nothing works. on top of that my boyfriend who insisted helping me misintrepreted one of the instructions on removing the bulb so you can route the wires instead of drilling holes, he actually put the wire there and burned out the instrument cluster. So basically no driving at night unless a flashlight pointed at the cluster and the dash where the radio, defroster, ashtray, a/c etc does not light up. *sigh* people like us need spoonfed tutorials
What's hot, sexy and has a stick?
my solara v6
hanatsuki
Postby krawzyazn » Wed Sep 21, 2005 3:18 am
is that a 5 speed? let me know I got one for both
Postby hanatsuki » Wed Sep 21, 2005 3:33 am
serious? yea, i have a 5 speed
my solara v6
hanatsuki
hanatsuki - mishap at DIY
Postby michaels artic frost » Wed Sep 21, 2005 5:21 am
hanatsuki,
Sorry to hear of your mishap attempt. Atleast Mark (krawzyazn) has one readily available for ya. I can vouch for him and so can the rest of the members on the forum. Very good guy, kinda krawzy at times but still a good guy...lolz...j/k Mark :wink: .
-Michael 8)
Updated 06/01/12: Michael T's
Postby Hsakuragi » Wed Sep 21, 2005 9:31 am
just make sure u use your own MIDDLE part of the cluster, that's where the car mileage stored..if not find a junk car with less mileage...heh
Hsakuragi
Postby krawzyazn » Wed Sep 21, 2005 9:42 am
pm me your #
Postby arch.HI » Wed Sep 21, 2005 10:43 am
Are you sure it's not just a blown fuse?
2000 Camry LE V6
TRD Supercharged
arch.HI
Postby SleeperSolara » Wed Sep 21, 2005 12:58 pm
Yeah couldn't it be a blown fuse.
How could you BF misread the instruction.
I let all my bulbs in in gauge cluster.
Just cut the top part of the black cluster cover between the clear cover and the white part, and routed the wires through there.
Good luck.
If you have the inverter wit just 2 wires for the power and ground wire. Also have an inverter wit dimmer.
Cause there is 2 diff inverters that can be bought for the white face gauges.
PM if you need help rewire the inverter wit the dimmer, and 2 wire that are red and black for power and ground.
I have found a way to rewire the inverter so tha tit stays blue and so you don't have to change it to blue to green.
Wanted to have just blue and not an extra dimmer or switch.
Postby arch.HI » Wed Sep 21, 2005 1:53 pm
Are you sure? I've blown my gauge cluster fuse before.
2000 Camry LE V6
TRD Supercharged
arch.HI
Postby hanatsuki » Wed Sep 21, 2005 2:54 pm
my bf said there was smoke coming out of the cluster when he wired it and i did check the fuse to see if it was blown, it wasnt.
my solara v6
hanatsuki
Postby Hsakuragi » Wed Sep 21, 2005 4:07 pm
u might just burnt the green piece in the back of the cluster...that's what happened to me..but i don't understand how it got involved to ur radio and a/c lights...
Hsakuragi
Postby Jackass-Jeff » Wed Sep 21, 2005 4:58 pm
There are various fuses for each part of the car. They are put in "Junction blocks". The junction block containing the fuses is located on the left of the steering wheel where that little "coin holder" compartment is... remote that little pocket and it's in there.
Fuse 3 = Gauges
Fuse 20 = Power
Just check all of them though... replace with the appropriate fuse size.
PM me your e-mail address and I'll send over a fuse diagram
Just in case, include the model year. They should all be about the same though
1GR-FE ftw!
Jackass-Jeff
Postby ~Spadwaller~ » Thu Sep 22, 2005 7:34 am
~Spadwaller~
Postby hskrsolara » Thu Sep 22, 2005 7:47 am
~Spadwaller~ wrote:http://cgi.ebay.com/ebaymotors/Speedometer-cluster-for-99-2002-Toyota-Solara-OEM_W0QQcmdZViewItemQQcategoryZ33678QQitemZ8001751593QQrdZ1
http://cgi.ebay.com/ebaymotors/1999-200 ... 2722QQrdZ1
Neither of these will work for her, she has a 5 spd, not an automatic.
hskrsolara
Postby krawzyazn » Thu Sep 22, 2005 10:17 am
I have the 5 speed and they ae RARE!!!
