SolaraGuy.com • View topic - EMERGENCY SALE: 2000 Toyota Solara 5 Speed TURBO
Postby Turbosolara » Thu Oct 06, 2005 12:27 am
I need money immedately, cash only $10000 FRIM take it. I have to sell it in two weeks and it come with all stock parts such as wheel, exhaust, suspension...etc. I also have recipets for most of parts and stuffs. if you like, you can part it out or tweak it up, it is up to your choice. the car runs wonderfully with 26mpg. the only flaw is the crank case seal leaks oil, but it doesnt drip. No check engine light and i will sell with smog. please email me at turbosolara@yahoo.com to see the car.
Here is the upgrade list. There might be some little thing i missed, but most of them are here.
2000 Toyota Solara,
5 speed manual, Diamond pearl white, clean title, 74000 miles
Upgrade list: (in/under MSRP)
Exterior:
TRD 7 piece aero kit $1,500
OEM style rear wing $300
18” Volk Racing TE37, white $1,500
Apexi dunk turbo series muffler 5” tip $200
Procarparts Euro style front corner light $45
LED signal light $25
Silver Star Super white headlight $42
Titanium 5 piece tint window $150
Shaved emblems
Hood lift venting
Interior:
TRD gauge sticker $5
Momo shift knob $80
TRD sports quick shifter $160
Levoic pedals $40
Apexi turbo timer with A/F ratio display $100
Greddy 60mm Electronic boost gauge $160
Autometer dual gauge pod $32
JDM clear clock $20
Greddy 60mm Electronic EGT gauge $170
Stereo
Concept CC-D1200A, 1200 W RMS Class-D mono block digital amp $350
Concept CPT-12, a pair 12” 500W RMS subwoofer $500
Rockford Fosgate 200.4 amp $180
Kenwood front component speakers $120
Pioneer 4 way rear deck speakers, 6x9 $80
Cancer 1.0 frad capacitor $95
Monster cables $50
Rockford Fosgate fuse boxes $40
Clarion DXZ750mp, 4 volt output $250
Toyota stereo storage pocket $20
Suspension:
Tokico Premium performance gas struts $360
TRD Eibach Pro-kit 1.5” lower springs $200
TRD adjustable rear anti-sway bar $180
Engine:
Custom Turbo kit from turbo-performance $3,400
Polished T3 turbo with .58 trim
Mandrel bent header
Blitz super sound blow off valve
Turbonuetics Deltagate Mark II wastegate
Spearco polished front mount intercooler
Custom Nicole plate piping and header
K&N air filter
3SGTE map sensor $50
Greddy oil catch can $90
Stainless steel oil lines, pressure pipes
Full custom 2.5” exhaust all the way $150
Magnecore 8,5mm spark wires $150
Denso Iridium IK22 $50
RC engineering 310cc fuel injectors $450
Greddy E-manage fuel computer + injector& ignition harness $370
Greddy Profec E-01 boost controller $500
Custom 4 gauge ground kit with gold plated terminal $40
Complete fuel system modification $700
Custom Earl stainless steel radiator pipe $45
TRD oil cap $35
Thrmowrap heat shield $50
Walbro 255 lph high flow fuel pump $100
valve cover vent modification $60 turbo total cost $7,090
dyno tunning $450
Brand new OEM oil pan $200
Brake
Rear disc brake conversion $350
Security
Lojack car tracking system $500
Viper Alarm $200
Total modification $14,894
2000 Toyota Solara, 2.2L, 5 speed $19,500
Grand Total $34,394
more detail here
http://members.dslextreme.com/users/tur ... index.html
Postby ThatVietGuy » Thu Oct 06, 2005 12:30 am
WTFFFFF WHY?!
ThatVietGuy
Postby Turbosolara » Thu Oct 06, 2005 12:40 am
I am having some finicial problem, i need 10G in two weeks.
Postby ThatVietGuy » Thu Oct 06, 2005 12:48 am
I see. Good luck with the sale.
ThatVietGuy
Postby Turbosolara » Thu Oct 06, 2005 12:49 am
Postby Sp33d » Thu Oct 06, 2005 12:51 am
damn man..thats some serious s#!7" yer in right now. good luck on the sales. if i had 10g's id buy that car straight up.
-mark
Sp33d
Postby ChargedSolara » Thu Oct 06, 2005 12:52 am
damn, sorry to hear about your situation, good luck selling that thing..its a clean ride
2008 C6 LS3
ChargedSolara
Postby Turbosolara » Thu Oct 06, 2005 1:18 am
Thanks guys, i also need to add more info
For 2AZ-FE owner would interested in using the turbo kit, I THINK you will only need a custom exhaust maniford and part of intake pipe piping. If best, get your fuel system modify to return kind and get the emanage tuned to your spec.
you can use MY:
T3 turbo
front mount intercooler (no cutting requires, direct bolts on)
part of intercooler piping
walbro 255lph high flow fuel pump
RC engineering injectors 310cc
Greddy E-manage
Greddy E-manage optional injector harness
Greddy E-manage optional ignition harness
Greddy Profec E-01 boost controller computer
Autometer Dual gauge pod
Greddy exhaust gas temperature
Greddy Boost gauge
Apexi turbo timer
Custom Apexi Dunk Catback exhaust system 2.5" with O2 simulator and bigger reflex pipe <- sounds like G35
Deltagate external wastegate
Blitz blow off valve
you can sell
5sfe turbo exhaust maniford
5sfe turbo polished downpipe
5sfe magnacore 8.5mm competition spark wire
3SGTE map sensor
moded 5sfe oil pan (just brought it at this year from dealer)
modifed fuel rail with 3SGTE fuel pressure regulator
keep in mind that all of my setting are very conservative. you certainly can get more hp from my setting right now
Postby Fletch » Thu Oct 06, 2005 4:18 am
Sorry to hear you have to sell. Hopefully you will find a buyer that is as enthusiastic about the car as you are.
2006 Legacy GT spec.B
Fletch
Postby xavier » Thu Oct 06, 2005 4:25 am
I love your car. Id hate to see ya lose it. May god bless you financially so you can keep yer baby!
xavier
Postby SleeperSolara » Thu Oct 06, 2005 6:43 am
That sucks man.
Good luck.
Postby SC V6 » Thu Oct 06, 2005 7:04 am
good luck with the sales
SC V6
Postby Sap Z » Thu Oct 06, 2005 7:14 am
thts an aesome deal man.
someone shud jump on it soon.
SapZ
V6 SE DWP
Sap Z
Postby RichD978 » Thu Oct 06, 2005 7:33 am
the financial curse of the DWP owners
RichD978
Postby hskrsolara » Thu Oct 06, 2005 7:35 am
I know many of us would pick it up in a heartbeat if we had the dough. Both of those cars are damn nice. Good luck with your sales.
hskrsolara
