SolaraGuy.com • View topic - FS: Brand new EricSol Big Brake kit!
Postby trd4life » Mon Jan 02, 2006 11:16 am
Brand new EricSol caliper relocation brackets with Supra TT cross drilled and slotted rotors.
$300 plus shipping
bump
Postby trd4life » Tue Jan 03, 2006 11:35 am
come on guys buy this brake kit. I cant use it with 15" drag rims. Requires a 17" rim.
Postby krawzyazn » Tue Jan 03, 2006 11:35 am
this is a great deal WITH ROTORS
Re: FS: Brand new EricSol Big Brake kit!
Postby Paladin06Greg » Tue Jan 03, 2006 11:58 am
Are these fronts?
trd4life wrote:Brand new EricSol caliper relocation brackets with Supra TT cross drilled and slotted rotors.
$300 plus shipping
Paladin06Greg
Torqued Solara
Torqued Solara
Postby krawzyazn » Tue Jan 03, 2006 11:58 am
Paladin06Greg wrote:Are these fronts?
$300 plus shipping
greg eric only made relocation kits for the front
big brakes
Postby trd4life » Tue Jan 03, 2006 12:34 pm
This is the same exact kit that Eric was selling a while back. Comes with the relocation brackets and hardware as well as the huge supraTT drilled/slotted rotors.
Postby sydemoid » Tue Jan 03, 2006 12:53 pm
Someone should jump on this, I bought my relocation brackets.... but Im also working on upgrading the whole brake system.... its been tedious gathering the info needed to complete this, but, I think that by mid feburary I should have something to show you guys...
I saw a Rotora kit for sale on here.... think about that for now... I might be able to get that same performance, with less weight (I hope), and quality components. All based on the EricSol relocation bracket.
Tax season is near... and I feel some 18 inch rims coming my way...
sydemoid
Postby Jon11582 » Tue Jan 03, 2006 11:28 pm
No way man. The Rotoras are a 4 piston set. Solara stock only has one piston per caliper. Plus the rotora kit comes with a bigger pad. This kit uses the same pad on a larger diameter disk.
Bigger rotors will increase your braking performance though.
Remember that you will need 17"s or bigger for these to fit.
2000 Black Solara SE
Jon11582
Postby TRD MCV20L » Wed Jan 04, 2006 12:07 am
So this is everything that I'd need? So I can use my stock pads and calipers if I buy this? Anyone have a picture of it installed?
TRD MCV20L
Postby 1kdude » Sat Mar 11, 2006 9:11 pm
Do you still have these for sale?
thanks,
1kdude
Postby trdkamuri51o » Sat Mar 11, 2006 9:59 pm
god i want it but i just got my heart set on a camera..
'oh well if its up in 1 month ill get it.. if not, great for the person who buys it..
this is a good deal..
trdkamuri51o
Postby Astro » Sun Mar 12, 2006 1:55 am
TRD MCV20L wrote:So this is everything that I'd need? So I can use my stock pads and calipers if I buy this? Anyone have a picture of it installed?
I don't know if this was sold but, here's a pic with 19" rims.
Postby Akfahad » Sun Mar 12, 2006 11:16 am
is it necessary for the caliper relocation brackets if your going to get slotted/drilled rotors? Or can you simply take off the stock rotors and put on slotted and be done? Know nothing about brakes.
Postby krawzyazn » Sun Mar 12, 2006 11:25 am
Akfahad wrote:is it necessary for the caliper relocation brackets if your going to get slotted/drilled rotors? Or can you simply take off the stock rotors and put on slotted and be done? Know nothing about brakes.
these are for bigger rotors you can change your stock ones out for slotted but if you want the bigger supra rotors then you need these
