SolaraGuy.com • View topic - F/S 1991 240sx Coupe, 5 speed with $7k invested
Postby Turbosolara » Mon Jan 16, 2006 7:13 pm
Untitled Document 1991 240sx SE coupe, White $4600 Firm. No trade and will not drop even a dollar. will not part out
198k miles, 2nd owner, good compression 155 all cylinders, recently smog, average 26 miles per gallon (24mpg - 27 mpg)
Cold AC, power steering, power window, power sunroof, keyless entry, alarm, 5 piece tinted window, Perfect dash, no rip, working HUD, Everything works good in the car. Nothing need to fix or replace, there is also no single oil leak or electrical problem. All the fuel line has been replaced and all of the services are up to date. I also have some service receipts
(R = Receipts available)
Service done in 2003 ($2117)
-New Genuine starter @ 185k miles (R: $277)
-New fan belt & front brake, replace clipers @ 185k miles (R: $623)
-Major services + power steering service (R” $698.56)
Service done in 2004
-water pump replacement and flush coolant @190k miles (R: $158)
-Replace clutch @192k miles (R: $360)
Recently just installed in March 2005: $4157
-New RSR Exmag Catback Exhaust (R $450) (R: labor $50)
-New KYB AGX Adjustable shocks (R: $365) (R: labor $150)
-New RSR Race Springs (R: $190)
-New Suspension Techniques Sway Bars Front & Back (R: $250)
-New Nissan Front Brake Pads
-New Car Alarm (R $160)
-New Window Tint (R $140)
-CD players with Pioneer speakers (R: $151 + labor R: $40)
-New K & N Filter (R $45)
-New Front Clear Corner Lights ($30)
-2 new tires
In October 2005: ($525)
-New OEM coolant temperature sensor & Harness ($45)
-New Koyo OEM radiator ($100)
-MAF sensor replacement ($25)
-New Bosch OEM O2 sensor (R $42.27)
-New iridium spark plugs ($40)
-New H4 projection head light conversion with super white bulbs ($30)
-New Renova blue Carbon Fiber cooling panel ($129)
-New OEM Fuel filter ($12)
-JDM Trust front strut bar installed ($80)
-New OEM valve cover gasket (R $20.90)
In December 2005: ($79)
-New OEM fuel pressure regulator installed (R $50)
-New OEM Cap and Rotor (R $29.31)
In January 2006: ($407)
-New Catco 2.5” high-flow Catalytic converter installed (R $90.50)
-New AEM short ram intake installed with AEM dry filter ($123)
-Transmission flushes with Synchromesh ($19)
-New Walbro 255 lph fuel pump ($100)
-New fuel pump seal (R: $9.69)
-Smog (R: $65)
Optional:
$500 for 16” Works 2 pieces wheel with tires (x4)
$60 for brand new OBX short shifter
NOTE:
-The climate contorl light bulb is out, that is the only problem it has
-The wheels in the rear are not included, that's optional wheel. you will receive the car with starndard SE alloy wheels.
-Interior: The XM radio receiver and Nismo shift knob are not included. cupholder is included.
-More photos in photobucket, including the AWSOME smog result. this baby runs like new
http://photobucket.com/albums/v640/trus ... t=smog.jpg
[/img]
Postby CASTRO » Sun Feb 05, 2006 7:54 pm
hey man, is the car still avail? i got an uncle whos very interested.
CASTRO
