FS 2: 5mm wheel spacers
anyone need these?
- RichD978
- SolaraGuy Semi-Pro Racer
methyl mike wrote:I def want some spacers but I need the kind that have bolts in them, so you basically bolt the spacer to the stock studs then the spacer itself has studs which you then bolt the wheel to. Any pics?
indiglosolara wrote:methyl mike wrote:I def want some spacers but I need the kind that have bolts in them, so you basically bolt the spacer to the stock studs then the spacer itself has studs which you then bolt the wheel to. Any pics?
I have a set of these from H&R. They are hubcentric..
its a 15mm spacer about 3/4" if not less.
Sorry Rich for hijacking your thread.
I'm selling them for $50.00 plus actual shipping.
If you are running 7 to 7.5 width rims with a 42 to 45 offset this will push the wheels outward and sit flush with the rear fenders.
CASTRO wrote:indiglosolara wrote:methyl mike wrote:I def want some spacers but I need the kind that have bolts in them, so you basically bolt the spacer to the stock studs then the spacer itself has studs which you then bolt the wheel to. Any pics?
kenny... you got PM
WTF?? wrote:CASTRO wrote:kenny... you got PMmethyl mike wrote:Hey I got to em first!RichD978 wrote:i already paid kenny!
kenny you got three set of balls after you... who are going to choose?? LMAO
