SolaraGuy.com • View topic - WTB RSB bushings...
WTB RSB bushings...
WTB RSB bushings...
Postby s15lara » Wed May 10, 2006 2:31 pm
just like the title says...anybody have any for the 99 solara? i misplaced them and now i need new ones asap. where can i get them or does anyone have any spare ones? pls help guys.
almost there...what do you think?
s15lara
Postby RichD978 » Wed May 10, 2006 2:35 pm
dealerships should sell them
RichD978
Postby NVDIS1 » Wed May 10, 2006 3:56 pm
trd ones or oem ones?
Postby trdkamuri51o » Wed May 10, 2006 8:46 pm
hey get us an update on your car man!!
trdkamuri51o
Postby solaraluv » Wed May 10, 2006 8:49 pm
RichD978 wrote:dealerships should sell them
^^^yeah like Rich said dealer hs them i changed mine last fall the part was like $16 if i remember correctly.
Loved by few hated by many
solaraluv
Postby s15lara » Wed May 10, 2006 10:44 pm
ok...well the car is actually just sitting in my garage right now till all the rain and everything is no longer in sight AND untill i can put on the RSB and the torque rod. ill have pics of the finished product up by monday or so...
back on topic though, the ones that i need are for the TRD rear sway bar. does the dealership carry those as well? if so i can stop by tomorrow and get them and have the rsb installed before friday.
anyone have the install instructions for the torque rod or the RSB? the one that Joeb did does not have the pics anymore (or my dumb comp is just being lazy and wont pop them up) and i really need them, same goes for the rsb. cant find anything for that...help guys. i wanna drive my baby again real soon...
s15lara
Postby xavier » Thu May 11, 2006 5:44 am
RSB is easy. Its 4 bolts and two nuts. The nuts are on a threaded ball-joint with a 5mm allen inset.
xavier
Postby SleeperSolara » Thu May 11, 2006 6:43 am
Torque Rod i've done.
I've had to take the radiatory fans for more room but that up to you.
The 2 bolts the hold the bracket of the OEM damper that bolts to the frame you can take those out to be easy.
And the loosen the bolt on top an then slide the old one out and put Jim's Torque Rod in the bracket and then bolt everythin' back up.
I pit some washers on both side the ball joint that hooks to the bracket that bolts the frame, so it doesn't move around.
Hope this helps.
Postby s15lara » Thu May 11, 2006 12:40 pm
so does anyone know where i can buy the busings for the trd rsb? before i go crazy? my car is just sitting there waiting for me to install the bar but i cant untill i get them bushings...can i get them at a dealer?
s15lara
Postby NVDIS1 » Thu May 11, 2006 3:58 pm
i will check when i go to work fri and i do have install instructions as well on rsb. Shoot i got a lot of the trd rsbs in stock so i can sell u the bushings from my display one 8)
Postby s15lara » Thu May 11, 2006 5:42 pm
thats perfect. just let me know when where and how...lol. im in dire need of it.
s15lara
