SolaraGuy.com • View topic - Electronics & Car Audio
Postby Adum-Bom » Thu May 18, 2006 6:31 pm
All items are OBO, I really would liek to sell it all this summer. Im shipping from Ashburn VA, 20147 if im not around to quote you on shipping, you can guestimate (USPS or UPS). So heres what ive got...
{Electronics}
Palm PDA+512SD *90+shipping*
Practically brand new Zire 31 with a Kingston 512MB SD card. I have 10 Belkin Clear Screen Overlays that are made for the Tungsten W & C (I had the C awhile ago), but I cut and fit to the 31. Has all cables, manuals, unit, perfect condition.
Creative Zen Touch *100+shipping*
http://memimage.cardomain.net/member_im ... 2_full.jpg
Also pretty new, I’ve used it for about 5 recharges. Battery life of around 20hrs and its 20gigs. Have all manuals, cables, and in perfect condition.
Dell Ac Adapter *10+shipping*
Suitable for Latitude C Series CP, CPi, CPiA, CPiD, CPiR, CPt, CPtc, CPtS, CPtV, CPxH, CPxJ, C500,C510 C600,C610,C640 C800, C810,C840 and DELL INSPIRON 3700 3800 4000 4100 5000 7500 8000 8100 8200 MODELS
Dell Port Replicator & Stand *90+shipping*
http://memimage.cardomain.net/member_im ... 6_full.jpg
In this bundle you get the D/Port Advanced Port Replicator for Dell Latitude D-Family Notebooks and the stand that props your laptop up at a more enjoyable viewing angle. The ONLY reason I’m selling is because our desks at school leave no room for my wrists when typing (look at the picture). The port replicator has TONS of connectors for your laptop and makes it easier for you to disconnect and go!
http://reviews.cnet.com/Dell_Inspiron_D ... 63784.html
{CAR AUDIO}|
2 Elemental Designs e12k *Both 80+shipping*
Dual 2ohm. One had its dust cap pushed in, and poped back out, plays just fine.
http://memimage.cardomain.net/member_im ... 5_full.jpg
http://www.cardomain.com/ride/836385
Qts. .36
Qms. 4.97
Qes. .39
Fs. 24hz
Vas. 83 L
Sensitivity 86.5 dB
Re. 1.75 Per Coil
xMax 15.8 mm
BL Product 20
Sd 490 825
Magnet Weight 100oz
Displacement .08 CF
Cut - Out Diameter 11 1/8"
High Excursion Back Plate yes
Speaker Weight 18lbs
Mounting Depth 5.9"
Minimum Rec. Power 75 Watts
Rec. RMS Power 400 Watts
Maximum RMS Power 900
4 gauge KnuKonceptz wiring kit w/ 5 extra fuses *20+shipping*
Wiring kit has been used and is missing a few terminal connectors, but will include a Scosche (Wal-Mart) 2 output distribution block for free.
Custom Fiberglass box for a TOYOTA SOLARA *70+shipping*
For two 12's. The cutout is ~11 1/8" Airspace is around 1.8cubes. Took days to build, and around $144. There would be a package deal on it if you bought it with the above subs.
http://memimage.cardomain.net/member_im ... 4_full.jpg
http://memimage.cardomain.net/member_im ... 9_full.jpg
Tsunumi Line level converter *10+shipping*
Allows you to use stock deck and connect an aftermarket amp.
99' SLE V6
My Garage
I can so some pretty SWEETTTTT jumps :)
Adum-Bom
