SolaraGuy.com • View topic - Like New FAL Dual Fan
Postby Paladin06Greg » Wed Aug 16, 2006 7:43 pm
Looks great and is very light weight. It just does not push enough air here in the AZ summer heat. Less then 100 miles on it.
$125 (+ shipping) or best offer. Cost $240 + brand new
Paladin06Greg
Torqued Solara
Torqued Solara
Postby hskrsolara » Wed Aug 16, 2006 7:45 pm
any pics?
or is my computer being retarded.
hskrsolara
Postby MCOjerry » Wed Aug 16, 2006 7:51 pm
Hate to sound stupid, but...what is a FAL?
Postby Sebas007 » Wed Aug 16, 2006 8:39 pm
I do not know either. :drinking:
MCOjerry wrote:Hate to sound stupid, but...what is a FAL?
Postby swindler » Wed Aug 16, 2006 8:51 pm
Flex-A-Light (or something like that) electric fan for your car. Takes the load off the engine to give you more HP, etc.
We're not as bad as AZ, but 105 today, for our 32nd 100+ day. We're not much better.
2006 SLE V6 Convertible
swindler
Re: Like New FAL Dual Fan
Postby DatSRBoi » Wed Aug 16, 2006 9:00 pm
Paladin06Greg wrote:Looks great and is very light weight. It just does not push enough air here in the AZ summer heat. Less then 100 miles on it.
Hey bro. GOt a question. Does it push more air then the stock ones? And why isnt it helping you in the heat? I get 100+ temp here too. SO is that bad?
Postby theprodigy79 » Wed Aug 16, 2006 9:00 pm
That's a very good price... Do you know if it will fit a Gen 2 properly? The radiators don't seem much different size wise, so I'm wondering if it can be jimmy-rigged if it doesn't fit perfectly to start...
theprodigy79
Not the fan, the hood scoop!
Postby ProRally Codriver » Wed Aug 16, 2006 9:20 pm
The fan pulls fine.
Your biggest problem is that your hood scoop functions only to create positive air pressure in your engine compartment which the fans have to fight to overcome. Plus 1 point from the car-show judges for installing a disfunctional hoodscoop, minus 20 points from the racecar engineer.
And its not the AZ heat either. The more power a given engine produces, the more heat. Adding headers, dual exhaust and intercooler piping creates more radiant heat in your stock engine compartment. The benefits of added capicity of oil and cooling abilities from the addition of your oil cooler is negated by your front mount intercooler and stock AC condensor blocking air thru your radiator.
The solution is to vent the hot air out of your engine compartment while creating negative/neutralizing air pressure in engine compartment so that air will pass thru radiator.
and/or, open up front bumper cover and/or remove AC condenser and/or get an aluminium radiator.
Last edited by ProRally Codriver on Wed Aug 16, 2006 9:58 pm, edited 1 time in total.
ProRally Codriver
Postby DatSRBoi » Wed Aug 16, 2006 9:37 pm
ProRally Codriver, arent you the brother of that one guy who screwed up a members car on here awhile back?
Nope
Postby ProRally Codriver » Wed Aug 16, 2006 9:45 pm
DatSRBoi wrote:ProRally Codriver, arent you the brother of that one guy who fluffied up a members car on here awhile back?
The one brother I have that is into cars builds only Mustangs.
ProRally Codriver
Easy
Postby JMSinMaryland » Wed Aug 16, 2006 9:50 pm
Pro-Rally, I've seen your bro-in-laws work and it's commendable, your attitude and constant putdowns, not so much so. Let your work/family work speak for itself.
JMSinMaryland
Postby SleeperSolara » Thu Aug 17, 2006 7:15 am
Hmmmmm......
"ProRally Codriver" is right though, not bein' on his side.
Greg you do need some reverse scoop to pull some hot air out though.
Postby Paladin06Greg » Thu Aug 17, 2006 4:38 pm
I posted a pic but I've no idea why it won't show. See a pic at my site.
hskrsolara wrote:any pics?
Paladin06Greg
Torqued Solara
Torqued Solara
Re: Not the fan, the hood scoop!
Postby dominoSLEV6 » Thu Aug 17, 2006 6:03 pm
Cough, cowl hood. Wow that would look funny on a solara. But he's right guys. something that outlets air is what is needed here, not something the fights the fans.
-chris
dominoSLEV6
Postby ProRally Codriver » Thu Aug 17, 2006 9:16 pm
dominoSLEV6 wrote:Cough, cowl hood. Wow that would look funny on a solara. But he's right guys. something that outlets air is what is needed here, not something the fights the fans.
Doesn't have to be in the hood. Many cars have vents or slits in their fenders for the same purpose. Some cars can remove trim from around windsheild wiper mounts for better airflow.
Having it vent out the hood is the best option as heat rises. Not only does it aid in cooling your engine compartment, but it allows air to escape at speed negating a parachute-effect causing big-time drag slowing your car and reducing gas milage and when parked after a drive, the heat can escape preventing heat damage/dry rotting of your coolant hoses and belts.
I can feel a torrent of heat pumping out the small pair of kidney vents in my hood after parking my car following a commute. More so than out of the large vent above my turbo, exhaust manifold and radiator.
Can be purchased here:
http://www.carbontrix.com/
and click on "Vents & Air ducts"
They also have Supra CF.
Try cooling a rallycar which has a skidplate blocking airflow out of bottom of engine compartment.
ProRally Codriver
