SolaraGuy.com • View topic - Ebay: TRD RSB $125
Ebay: TRD RSB $125
Ebay: TRD RSB $125
Postby krawzyazn » Sun Feb 04, 2007 7:29 pm
Postby Ruski » Sun Feb 04, 2007 7:38 pm
Great Find.. Nice he has a charcoal canister Perfect..
krawzyazn the siennia van has the same engine as the solara correct. do u think the canister will work from a sienna to me solara ?? OF Topic I know
Postby krawzyazn » Sun Feb 04, 2007 8:04 pm
I dunno I just saw this on ebay
Postby SolaraBlue » Sun Feb 04, 2007 8:43 pm
i just had mine installed. very much worth it.
which hole is track and which street? i have mine set on the outter most hole.....
Postby ThatVietGuy » Sun Feb 04, 2007 8:45 pm
Inner is track
ThatVietGuy
Postby 99V6solaraSE » Sun Feb 04, 2007 9:14 pm
if i have a slight frame damage which shifted slightly right.. would their be a problem with installing this?
99V6solaraSE
Postby Nyyankees3511 » Sun Feb 04, 2007 9:20 pm
It depends, how does your oem sway bar look? If its not bent or anything then you should have no trouble with the trd.
Nyyankees3511
Postby SolaraBlue » Sun Feb 04, 2007 9:22 pm
^^^ if the rear is damaged you might. tough to say...
buy it anyway. you wont regret it even if you have to wait a bit to install it....
Postby unbalancedwood » Mon Feb 05, 2007 6:20 am
NVDIS1 has them for $150 shipped...
Ill buy mine from him when i get the $
unbalancedwood
