SolaraGuy.com • View topic - FS: Link to Enduro Ksport Coilovers for $907.20
Postby Toy1mzfe » Fri Feb 23, 2007 8:29 pm
Sorry im not sure where to post it, but i think it would be koo for others to know there are more options for coilovers.
Well i was on another forum, Nocaltuners.com, and there is a guy thats selling Brand new ksport coilovers.
and heres the deal from a vendor named Enduro:
We are having a super sale on Ksport Coilovers. These prices are to low to post. Garunteed Best price on the net!.. We havent even uploaded them on our own SITE!! Some applications instock, ones that are not instock are a 4-5 day eta direct from Ksport in AZ.
Ksport Kontrol Pro
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features:
* 36-way adjustable dampening
* Made from high quality 6061 Aluminum w T6 for increased hardness
* Compression/Rebound adjustable
* Adjustable spring perch for height adjustment
* Adjustable body allowing maximum suspension travel
* Pillow Ball Top Mount w/ adjustable camber (some models)
* Monotube High Pressure Design reduces oil leakage
* Electroplated body for protection from corrosion and rust
* One Year Limited Warranty
Images:
Here is the Pm i got after asking him for a 99 Solara SE v6
Ksport coilovers
Toyota Camry
1997-2001
#CTY03-KP
MSRP: $1400.00
EM:$840.00
Sales Tax: $67.20
Total: $907.20
Free shipping is included. Let me know if you are interested. Also included is a $50 gift certificate to Enduro. Not usable with this transaction but future ones garuntee.
and here is the link to his posting:
http://norcaltuners.com/viewtopic.php?t=4022&highlight=
If I was not allowed to put this up.. my bad..
Postby PiterNYC » Fri Feb 23, 2007 8:55 pm
You can get them on ebay for 910 $ plus shipping, heres a link:
http://cgi.ebay.com/ebaymotors/Ksport-C ... enameZWD1V
PiterNYC
Postby unbalancedwood » Fri Feb 23, 2007 9:01 pm
So you save $32.80 with this link deal, thats decent, worth mentioning i guess
Does anyone have these?
unbalancedwood
Postby Toy1mzfe » Fri Feb 23, 2007 9:09 pm
whoops, i didnt check out ebay for their prices but thanks for the info.
Postby krawzyazn » Fri Feb 23, 2007 10:06 pm
just get Tein
Postby Akfahad » Fri Feb 23, 2007 10:49 pm
never heard of this brand before. Reputable?
Postby krawzyazn » Fri Feb 23, 2007 11:36 pm
Akfahad wrote:never heard of this brand before. Reputable?
I think milt has them on his camrys
Postby ---CAMRAZY--- » Sat Feb 24, 2007 2:30 am
They are okay, My riced out camrys only have 2 options, D2 and Ksport.... Which are both by the same maker. Get JIC or Tein or even B&G for the solara before these.
Postby trdkamuri51o » Sat Feb 24, 2007 9:50 pm
well thanks for clearing it up milton.. i was considering a set...
trdkamuri51o
