SolaraGuy.com • View topic - FS DFW: Goodridge SS Brake Line
Postby salaki » Wed Apr 18, 2007 10:57 pm
SOLD!
Happy_Aggies former S/C 99 Solara
salaki
Postby funboy102 » Fri Apr 20, 2007 1:13 pm
how easy is it to install the lines? got directions?
funboy102
Postby salaki » Fri Apr 20, 2007 2:02 pm
funboy102 wrote:how easy is it to install the lines? got directions?
It's fairly easy to install lines.
If you have installed lowering suspension, I am sure you can perform this installation.
I only have instructions specific to Impreza which is basically very similar to Solara. The only different is that Solara uses 10mm bolt to hold the lines to the struts instead of Clip.
Here's how to install the lines:
http://www.rollyourfender.com/instructi ... 20Hose.pdf
MAKE SURE YOU BUY FLARE 10mm WRENCH other wise you will round the nut.
If you did, don't freak out, there's always a vise grip :P
Make sure you install the new copper washers provided w/ the brake lines.
Here's how to bleed the brake fluid:
http://www.rollyourfender.com/instructi ... eeding.pdf
If you don't track your car, Valvoline Synthetic from Autozone/Local part store is the best deal you can find for daily drive w/ very good high/low boiling/wet points for the price (almost as good as ATE Super Blue but 1/2 the price)
Hell. I even use Valvoline for track days and it held just fine.
Bleeding the brake can be a bit tricky but not hard but it takes time.
This is a good time if you want to buy Speed Bleeders to make jobs easier.
If you don't want to buy Speed bleeders then you may need help from another person.
Basically after you install the new lines, you will have air in your brake system.
W/o Speed bleeders:
Assign a friend to monitor the brake fluid reservoir and to always keep it full.
Assign another one in the passenger seat to press/depress the brake pedal.
Start engine, open the bleeder valve then tell a friend to brake and keep it braked.
You will see air /bubbles flowing w/ dirty fluid, once it stops flowing then close the bleeder valve, tell him to release the brake.
Repeat above steps until you don't see anymore air bubbles and you see clean fluids.
W/ Speed bleeders:
You will see air /bubbles flowing w/ dirty fluid, once it stops flowing ask him to release the brake then repeat.
Combine this w/ Axxis Ultimate or HPS or maybe others, and good blank Brembo rotors then you will smile every time you brake.
I hope that helps out :)
Let me know.. :)
salaki
Postby SleeperSolara » Mon Apr 23, 2007 8:08 am
The lines are new right??
In your first picture it looks like they've been used....
Postby salaki » Mon Apr 23, 2007 8:16 am
SleeperSolara wrote:The lines are new right??
2 lines are brand new and 2 were 1% used? :)
2 were (let's say 99% brand new) test fitted onto MY04 STi to try if they fit but never even bled the system.
Basically the four lines have never seen a compressed brake fluids at all and were never driven at all.
It looks a bit dirty because you are seeing the pouch that holds the copper washers that I touched w/ my dirty hand.
Thanks...
salaki
Postby unbalancedwood » Mon Apr 23, 2007 8:20 am
One line was test fitted onto my MY04 STi (did not even drive w/ the line) "
I think there all 'new' only thing that looks dirty is that white plastic packet...
unbalancedwood
Postby salaki » Mon Apr 23, 2007 8:23 am
Revised my posts above.
I forgot that I tested fitted two lines so they are about 98% brand new :lol:
Sorry about the confusion but Yes. these lines never seen high pressured brake fluids (driven with)
salaki
Postby DatSRBoi » Mon Apr 23, 2007 8:44 am
Ahhh I remember that car. Been a long time since I seen it considering i live so close.
Postby salaki » Fri May 04, 2007 7:17 pm
SOLD!
Thanks for your interests :)
salaki
