SolaraGuy.com • View topic - Group Buy: Cp-e MAFci (ALL GENERATIONS)
Postby SleeperSolara » Mon Sep 17, 2007 9:12 pm
Bump.
Is this still happenin'??
Postby unbalancedwood » Wed Sep 19, 2007 5:24 am
I still want it to.... :(
unbalancedwood
Postby Sebas007 » Wed Sep 19, 2007 6:08 am
It would work better if it was an unnessecary LED shity blip blip cover Group Buy...few people on here are serious about engine modding here.
Postby Biggi_e » Wed Sep 19, 2007 6:28 am
to whomever installs the cp-e, its better to solder the wires together than crimping it. you will get the best connection soldering it.
Postby unbalancedwood » Wed Sep 19, 2007 7:04 am
darn wish i knew that gess ill have to have my soder gun shipped to me
unbalancedwood
Postby SleeperSolara » Wed Sep 19, 2007 10:09 am
unbalancedwood wrote:I still want it to.... :(
So this is G/B is down the drain??
Postby unbalancedwood » Wed Sep 19, 2007 2:15 pm
I think netherland and i are the only ones who are in...
anyone else?
unbalancedwood
Postby JvR » Wed Sep 19, 2007 3:34 pm
Netherland, do you live in the Netherlands or not (anymore)?
JvR
Postby SleeperSolara » Thu Sep 20, 2007 9:02 am
unbalancedwood wrote:I think netherland and i are the only ones who are in...
anyone else?
So the list right now is:
1.unbalancedwood
2. netherland
3. SleeperSolara
I guess it's just 3 people. :-?
If it takes too long i'm goin' to buy another mod for my car then....... :(
Postby Sebas007 » Thu Sep 20, 2007 10:08 am
Why don't you guys buy it on your own seeing that great but unpopular GB ? It is an only 40$ difference.
Postby unbalancedwood » Thu Sep 20, 2007 1:35 pm
^ Im willing to but were just trying to get something done here i guess.
Josh has let the GB go for another 2 weeks though if we like...anyone on the fence?
unbalancedwood
Postby SolaraGuy22 » Sun Sep 23, 2007 11:53 pm
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Re: Group Buy: Cp-e MAFci (ALL GENERATIONS)
Postby JMSinMaryland » Sat Sep 29, 2007 4:06 pm
JavaJoe_2 wrote:
crispone wrote:
JavaJoe_2 wrote:I have it 80% wired in...I can't seem to get a steady RPM reading.
If you don't have a steady RPM, either something is wrong with your car, or you have goofed on the install, I would think.
The car is fine except for my goofed wire tap.
I can manipulate the ecu..so I know that works.
There are no installation guide or Help from CP-e on a Camry.
The ECU is wired differently than the Solara.
Just posting this up for interested Camry owners.
And, if you're spending the money GET THE TUNABLE!
1. Do you have to touch the ECU if you get a non-tunable version? Are you having an issues BECAUSE yours is tunable and you can't get it to tune right or do you have the non-tunable version?
2. How do you tune it? Dyno?
JMSinMaryland
Postby JavaJoe_2 » Sat Sep 29, 2007 5:12 pm
JMSinMaryland wrote:1. Do you have to touch the ECU if you get a non-tunable version? Yes. You have to wire it in between the MAF and ECU.
Are you having an issues BECAUSE yours is tunable No
and you can't get it to tune right or do you have the non-tunable version? Tunable version. I'm just having a wiring issue. Runs GREAT!
2. How do you tune it? Dyno? Yes Dyno. I'm going to have that done. It interfaces with software for tuning.
Again, I love it. I didn't want the SAFCII for tuning purposes. I don't need another thing to mount in the interior. Once I set it it's done! :D
Got Boost?? :sweet:
JavaJoe_2
Postby Sebas007 » Sat Sep 29, 2007 6:07 pm
JMSinMaryland wrote:1. Do you have to touch the ECU if you get a non-tunable version? Are you having an issues BECAUSE yours is tunable and you can't get it to tune right or do you have the non-tunable version?
Tunable and non-tunable have the same mapping. The only thing with the tunable is that you can modify the mapping with an included software. The basics are :
- the data is displayed on a 2 axis scale. Horizontal axis is voltage (0-5 volts) coming of the throttle demand. Vertical axis is RPM...so you can figure it out...the part of the mapping you want to modify is high demand (4/5+) at high RPM (3800+).
The stock mapping of the car is pretty rich...you have to lean it. CP-e already dyno-tune all the cars with stock setup but if you had some of the thing you might want to play with your AFR. The number you enter each cell means the % of volt in less you want. Because a low value in the ECU means leaner AFR you want to ask him to manage a full throttle at 5000RPM as it would manage it normally for a full throttle but at 4500 RPM makeing it leaner. Just as an exemple if I put 5 in a cell it would means that for that specific Throttle position/RPM I ask the ECU to give me the mapping minus 5%.
Since the CP-e does not replace the ECU at all but instead catch the volt signal before arriving to the ECU go thru the CP-e box to modify the volt signal and then go to the ECU.
