SolaraGuy.com • View topic - MSD DIS-4 with 2 tach adapters
Postby SC V6 » Fri Sep 28, 2007 11:46 am
I started a new post for my MSD ignition that is for sale. Sale fell through... This is a great upgrade for a S/C application... Wires are already wired, all you have to do is connect a 12v source, ground, and connect wires to the coils. Really simple, and I can even type out a wiring diagram so its even easier.
Will ship it out this instant for $320 shipped to your door!!!
Great upgrade
Over $600 for the MSD DIS-4 alone!
SC V6
Postby Dawgz » Fri Sep 28, 2007 1:08 pm
hey, how easy of an install is this?
can i use it on my automatic?
and what are the benifits....
sorry but i dono what the msd is....i remember u telling me that its good for s\ced cars
Postby SC V6 » Fri Sep 28, 2007 1:26 pm
Install is pretty simple compared to a S/C install...
You have to connect it to a 12v source, and a ground of course. Then you will need to cut tap each of the wires that go to the coils.. (6 wires)... then find a place to mount the MSD.
you can use it on an auto... bascially what the MSD does is amps the signal/voltage to the spark plug, and has generates a spark that is much more powerful than the stock ignition system... it basically insures that all of the fuel is being ignited, making more power... The reason this is such a plus for supercharged people is that when the supercharger crams air into the cylinder, it creates a swirling effect, and makes it so the stock ignition system isn't as good anymore.. this MSD ignition insures that the fuel is being ignited...
Also, you can set a rev-limiter on the MSD, as well as setup a staging RPM, so you can Floor the pedal, and the msd only lets it ramp the rpm's up to a certain signal, till you flip the switch to allow the MSD to rev the motor higher... I never used the staging settings, but the effects of the MSD were definitally felt using my larger injectors and the IK22's
I can also type up what wires (colors) go to which wires on the MSD... its pretty simple
SC V6
Postby Dawgz » Fri Sep 28, 2007 1:45 pm
hmm, let me research this on this weekend and get back to u, im interested tho.
Postby SC V6 » Fri Sep 28, 2007 2:31 pm
sounds good... its truly an impressive upgrade
SC V6
Postby SC V6 » Sun Sep 30, 2007 12:26 pm
BUMP!!!!
SC V6
Postby SC V6 » Tue Oct 02, 2007 6:42 am
bump
SC V6
