SolaraGuy.com • View topic - WTB: Ignition Coil/s for 1mz-Fe
Postby SolAraB » Mon Nov 05, 2007 1:39 pm
Hey everyone yea so i think that i have come to the conclusion that i need new Ignition coils...............i keep getting CEL and last time i checked it said that cylinders 2 4 and 6 were misfiring which i believe are the 3 plugs in the back. All plugs are fairly new and i have NGK's that are even newer. So my only guess is that my Coils are bad or one of the coils is bad.. ....... is there anyway to test our coils for the V6 to see whether they are bad or not? :( Please Help
SolAraB
Postby Chinky420 » Mon Nov 05, 2007 7:06 pm
...i think that bank 1 is the rear bank (near the firewall), which would be cylinders 1, 3, and 5...
making cylinders 2, 4, and 6 the ones near the radiator. i may be mistaken, but you might want to double check that fact.
if you upgraded you plugs/wires recently, check that everything is connected properly. if not that, then possibly the coils.
good luck
Chinky420
Postby Chinky420 » Mon Nov 05, 2007 7:08 pm
Chinky420
Postby Chinky420 » Mon Nov 05, 2007 7:11 pm
...dang server freezing up...making me re-submit the post 3 times...
my bad guys
Chinky420
Re: WTB: Ignition Coil/s for 1mz-Fe
Postby Ruski » Mon Nov 05, 2007 7:18 pm
SolAraB wrote:Hey everyone yea so i think that i have come to the conclusion that i need new Ignition coils...............i keep getting CEL and last time i checked it said that cylinders 2 4 and 6 were misfiring which i believe are the 3 plugs in the back. All plugs are fairly new and i have NGK's that are even newer. So my only guess is that my Coils are bad or one of the coils is bad.. ....... is there anyway to test our coils for the V6 to see whether they are bad or not? :( Please Help
There is away to test it , what i did on my lara was bought another coil and switched each one at a time till i stopped getting the cel. which was cyl 6 misfire
