SolaraGuy.com • View topic - WTB Black headlights w/sides
Postby 2kSoulara » Tue Feb 26, 2008 8:54 am
Anyone have the black hedlights for 2k solara they re not using? I'd like to get a set so i can put projectors in them. PM me. Thanks
2kSoulara
Postby shocar4 » Tue Feb 26, 2008 9:02 am
if you are going to do projectors then just do your black headlights yourself! i did my own and i am getting ready to do a set for another member for $50! it takes alot of time to do, but you still have the oem light output and it's cheaper! just my two cents!
shocar4
Postby 2kSoulara » Tue Feb 26, 2008 9:33 am
True but my night vision is weak so i need as much light as possible. Thanks for the info though
2kSoulara
Postby bronzemaxell » Tue Feb 26, 2008 10:15 am
2kSoulara wrote:True but my night vision is weak so i need as much light as possible. Thanks for the info though
from what i read here in this forum,
the blackout headlight housing are aftermarket poor quality made in taiwan sh!t, give very poor illuminiation on road, and the craftmanship is also very poor, just for show and look
OEM headlight still the best.
bronzemaxell
Postby akora12 » Tue Feb 26, 2008 10:38 am
It's really easy to make your own for little cost and the light output is the same as OEM. Trust me, I've had my headlights and foglights apart several times with no problems.
Postby 2kSoulara » Tue Feb 26, 2008 11:45 am
I had a set of black hedlights before and yes they did suck as far as light output. I cracked one of them so i went back to the stocks. I just want the blak ones for the casing so i can put projectors in them. OEM light output is good but like i stated before i need more light at night. HIDs are good but the added benefit of projectors will make it better. maybe some of you guys have your old black headlights that you used but then changed.
2kSoulara
Postby BlKSo|aRa » Tue Feb 26, 2008 1:36 pm
shocar4 wrote:if you are going to do projectors then just do your black headlights yourself! i did my own and i am getting ready to do a set for another member for $50! it takes alot of time to do, but you still have the oem light output and it's cheaper! just my two cents!
info on how u do them? i saw some guy took it aprt n put it in the oven.
BlKSo|aRa
Postby shocar4 » Tue Feb 26, 2008 1:40 pm
look in the tutorial section!
shocar4
Postby bronzemaxell » Tue Feb 26, 2008 7:49 pm
i was one of them brave enough to bake them
read one of my post here
http://www.solaraguy.com/viewtopic.php?t=34538&start=15
bronzemaxell
Postby krawzyazn » Tue Feb 26, 2008 8:50 pm
and I was the one to open mine with out baking or heating them
