SolaraGuy.com • View topic - SUPRA TT BRACKETS PICTURES PG.8
Postby Sp33d » Tue Aug 05, 2008 2:18 pm
Nuts/Bolts/Washers/Brackets are all in.
The brackets are of tougher/better material and with a BETTER finish than ericsol's brackets. They look sweet.
Ready to be shipped. Paypal can be sent to
[/b]mark_huynh@msn.com for the amount of $200
the 200 is w/ paypal/ shipping fees. =)
Please include the following in the message portion
*Address
*Solaraguy Alias (i.e. sp33d)
-Mark
Sp33d
Postby Solarizona » Tue Aug 05, 2008 2:54 pm
Ok, I'm sure this is a total noob question but...do you have to upgrade the calipers/pads for the bigger rotor? I don't remember seeing anything mentioned about the calipers in previous posts.
Solarizona
Postby akora12 » Tue Aug 05, 2008 3:13 pm
Solarizona wrote:Ok, I'm sure this is a total noob question but...do you have to upgrade the calipers/pads for the bigger rotor? I don't remember seeing anything mentioned about the calipers in previous posts.
These brackets just push the factory caliper out further to accomodate larger rotors. I'm sure you can use whatever pads you want.
I'll take a set assuming they work with a 17" wheel. I'm too lazy right now to search if that's a possibility.
BTW, it's about time someone did this.
Postby hskrsolara » Tue Aug 05, 2008 3:27 pm
these are just for the fronts correct?
hskrsolara
Postby sydemoid » Tue Aug 05, 2008 3:42 pm
they are meant for 17" rims, stock calipers work on Supra TT rotors, you notice serious brake torque at speeds.
depending on how you drive, you might want to consider high abrasion brake pads, like full metallic, ceramic, or carbon metallic. Stainless steel braided lines also help a lot!
Upgrade to DOT 4 brake fluid, and you are set.
GL with the group buy!
sydemoid
Postby Dawgz » Tue Aug 05, 2008 4:39 pm
Did u find out what kind of material they will be made of?
The originals were Aircraft aluminum from what i was told...
Postby Sp33d » Tue Aug 05, 2008 4:45 pm
these will fit for 17's or larger rims.
made out of lightweight aircraft aluminum.
upgrade of brake pads is ideal with stainless steel brake lines.
no new calipers needed. stock 2 piston calipers is ok.
Sp33d
Postby Dawgz » Tue Aug 05, 2008 4:53 pm
Good stuff!
Postby krawzyazn » Tue Aug 05, 2008 5:14 pm
Sp33d wrote:these will fit for 17's or larger rims.
stock 1 piston you mean
Postby lightear » Tue Aug 05, 2008 5:17 pm
Count me in.
lightear
Postby akora12 » Tue Aug 05, 2008 5:26 pm
I'll start up the list...
1) akora12
2) lightear
3)
4)
5)
6)
7)
8 )
9)
10)
Postby r0w » Tue Aug 05, 2008 5:29 pm
Mark I've started a list to get the ball rolling, Add you're name to the list.
1.akora12
2.lightear
3.r0w
4.
5.
6.
7.
8.
9.
10.
r0w
Postby Solarizona » Tue Aug 05, 2008 5:33 pm
I'm in since I seriously doubt the ypipe GB will go through - and these will be done a lot sooner.
1.akora12
2.lightear
3.r0w
4.Solarizona
5.
6.
7.
8.
9.
10.
Solarizona
Postby JavaJoe_2 » Tue Aug 05, 2008 6:04 pm
I still have the original install instructions if you need them.
Got Boost?? :sweet:
JavaJoe_2
Postby Dawgz » Tue Aug 05, 2008 6:17 pm
2
