SolaraGuy.com • View topic - WTB Charcoal Canister
Postby DaZanY4002 » Mon Aug 11, 2008 11:03 pm
Hey guys. My plates have finally expired and my car's got the CEL for 2 PO466 codes. I could pay the guy $120 to pass smog, but thought I'd check on here and see if someone has one they don't need, before I head to a salvage yard. I need the charcoal canister, which I don't care if it's used as long as it's good, and then, I think it was called, something like the vapor pressure hose, but I think I'll get that from Toyota. Thanks in advance for any help.
-Danny
DaZanY4002
Postby 5sfe » Tue Aug 12, 2008 1:42 am
its not your Charcoal Canister.. you need three different emission codes so it can be the canister.. your code is P0466 Purge Flow Sensor Circuit Range/Performance. the second code should say the same thing only with pending on the bottom or top of the obd scanner..you are fine nothing ex stream.. go to the dealer and ask for the purge flow sensor don't expect it to be cheap everything for the gen1-1.5 toyota solara is really expensive...Good luck
5sfe
