SolaraGuy.com • View topic - I need an EGR for a 1MZFE
Postby GreenSolara01 » Thu Sep 04, 2008 8:28 pm
Mine is dead just wanted to see if there was one out there for aa SLE?
GreenSolara01
Postby ASG14 » Thu Sep 04, 2008 8:37 pm
The EGR Valve or the Modulator (plastic part)?. Many people think the Valve is bad when it;s the Modulator.
ASG14
Postby GreenSolara01 » Thu Sep 04, 2008 8:47 pm
GreenSolara01 wrote:Code came back. Also I checked the EGR. It doesn't have a vacuum. Funny thing is I checked the position sensor and it's bad too. not LOL not at all
GreenSolara01
Postby Gregtrd » Thu Sep 04, 2008 9:24 pm
ASG14 wrote:The EGR Valve or the Modulator (plastic part)?. Many people think the Valve is bad when it;s the Modulator.
I thought that the 1mz only had a egr valve or is it all built on the same valve, where's the modulator. The 5sfe does has modulator but not sure about 1mz. I got two 1mz valves if you need one
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby Camry Racing » Thu Sep 04, 2008 9:33 pm
eliminate the EGR system is better and cheaper but you will get a cel eternally
Camry Racing
